Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 14 tutoriels qui comprennent cette étape.
Traduction de l’étape 11
Étape 11
Remove the logic board screws
Remove the following 8 screws:
Five 2.3 mm Phillips #00 screws with partial threads securing the logic board to the rear case.
Two 2.3 mm Phillips #00 screws with full threads securing the logic board and camera.
One 2.9 mm Phillips #00 screw from beneath the "Do not remove" sticker.
Note for re-assembly:
The screw that goes next to the camera (bottom right orange highlighted screw) also has a metal strip that holds the camera in place.
+ | [title] Remove the logic board screws |
[* black] Remove the following 8 screws: | |
[* red] Five 2.3 mm Phillips #00 screws with partial threads securing the logic board to the rear case. | |
[* orange] Two 2.3 mm Phillips #00 screws with full threads securing the logic board and camera. | |
[* yellow] One 2.9 mm Phillips #00 screw from beneath the "Do not remove" sticker. | |
[* black] Note for re-assembly: | |
[* black] The screw that goes next to the camera (bottom right orange highlighted screw) also has a metal strip that holds the camera in place. | |
- | [* icon_reminder] Remember to put this strip back in place before you insert the 2.3 mm Phillips #00 |
+ | [* icon_reminder] Remember to put this strip back in place before you insert the 2.3 mm Phillips #00 screw with full thread next to the camera |
