Aller au contenu principal
Remplacement des haut-parleurs Canon Powershot A610
Anglais
Français
Traduction de l’étape 9
Étape 9
Canon Powershot A610 Speaker Replacement: étape 0, image 1 de 2 Canon Powershot A610 Speaker Replacement: étape 0, image 2 de 2
  • Use an unfolded paper clip to push the speaker from the top of the casing out towards the bottom.
  • Use a bit of force as the speaker is glued into the top casing.
  • There is a soft fabric speaker cover separating the speaker from the casing. Make sure not to remove it from its position in the housing.
Utilisez un trombone déplié pour pousser le haut-parleur du haut du boîtier vers le bas.
Vous devrez peut-être utiliser un peu de force lorsque l'enceinte sera collée dans le boîtier supérieur.
Un couvercle d'enceinte en tissu doux sépare l'enceinte du boîtier. Veillez à ne pas le retirer de sa position dans le boîtier.
[* black] Use an unfolded paper clip to push the speaker from the top of the casing out towards the bottom.
-[* black] You may need to use a bit of force as the speaker be glued in to the top casing.
+[* black] Use a bit of force as the speaker is glued into the top casing.
[* icon_note] There is a soft fabric speaker cover separating the speaker from the casing. Make sure not to remove it from its position in the housing.
