Aller au contenu principal
Remplacement du lecteur optique du MacBook Core 2 Duo
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 22 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
MacBook Core 2 Duo Optical Drive Replacement: étape 0, image 1 de 1
  • Disconnect the newly-revealed hard drive cable's plug from the logic board by pulling it upward using its black tab.
  • When reconnecting the hard drive cable's plug to the logic board, make sure the plug is routed under the cables for the right speaker and the microphone, or else the plug won't sit flush with the logic board, which will prevent the plug from fully engaging with its socket on the logic board.
Débranchez le câble du disque dur auquel vous avez maintenant accès.
-[* black] Disconnect the (once again) newly-revealed hard drive cable.
+[* black] Disconnect the newly-revealed hard drive cable's plug from the logic board by pulling it upward using its black tab.
+[* icon_note] When reconnecting the hard drive cable's plug to the logic board, make sure the plug is routed under the cables for the right speaker and the microphone, or else the plug won't sit flush with the logic board, which will prevent the plug from fully engaging with its socket on the logic board.
