Aller au contenu principal
How to reduce ChiliCube noise level by replacing fans
Anglais
Français
Traduction de l’étape 5
Étape 5
How to reduce ChiliCube noise level by replacing fans, Remove connection to top of case: étape 0, image 1 de 2 How to reduce ChiliCube noise level by replacing fans, Remove connection to top of case: étape 0, image 2 de 2
  • There is a small circuit board attached to the top part of the case for buttons and display readout. It is connected to the main circuit board on the unit by a small cable.
  • Unhook connector this small ribbon cable from the main circuit bord on the bottom of the unit (which is now facing you.)
  • The connector should pull out without needing to be released in any way.
Insérez ici votre traduction
