Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Ensure that the device is turned off before beginning. Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point. Be careful if using the metal spudger, as it can scratch the surface of the Kindle.
  • Ensure that the device is turned off before beginning.
  • Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point.
  • Be careful if using the metal spudger, as it can scratch the surface of the Kindle.
Insérez ici votre traduction
