Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 6 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Pry under the left edge of the home button cable connector to disconnect it from its socket. If the entire connector begins to flip up without separating, press down on the cable at the top edge of the connector with the flat of your spudger, while simultaneously prying up the left edge of the connector. Be very careful not to damage the cable or connector, or you will permanently disable the sensor. If the entire connector begins to flip up without separating, press down on the cable at the top edge of the connector with the flat of your spudger, while simultaneously prying up the left edge of the connector. Be very careful not to damage the cable or connector, or you will permanently disable the sensor.
Déconnectez la nappe du capteur home/Touch ID en faisant délicatement levier sur son connecteur à pression.
[* black] DisconnectPry under the home/Touch ID sensorleft edge of the home button cable by carefully prying openconnector to disconnect it from its presssocket.
[* icon_caution] If the entire connector begins to flip up without separating, [https://d3nevzfk7ii3be.cloudfront.net/igi/YCREWlQsUNsbXdMn.full|press down on the cable at the top edge of the connector with the flat of your spudger|new_window=true], while simultaneously prying up the left edge of the
