Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 6 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
Heating the area around the home/Touch ID sensor will help soften the adhesive holding its delicate cable in place, making it easier to remove safely.
  • Heating the area around the home/Touch ID sensor will help soften the adhesive holding its delicate cable in place, making it easier to remove safely.
  • Flip the display assembly over. Use a hairdryer or prepare an iOpener and apply it to the lower edge of the display for about 90 seconds in order to soften up the adhesive underneath.
Retournez l'écran complet et posez un iOpener chauffé sur la partie où se situe le capteur home/Touch ID pendant environ 90 secondes.
Ceci permettra de ramollir l'adhésif qui maintient la nappe délicate du capteur.
[* icon_note] Heating the area around the home/Touch ID sensor will help soften the adhesive holding its delicate cable in place, making it easier to remove safely.
black] Flip the display assembly over,over. Use a hairdryer or [guide|25705|prepare an iOpener|new_window=true] and apply a warm iOpenerit to the home/Touch ID sensor arealower edge of the display for about 90 seconds.
[* icon_note] This will help
seconds in order to soften up the adhesive holding the delicate sensor cable in placeunderneath.
