Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 6 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 6
Étape 6
Use an opening pick to gently separate the adhesive holding the home/Touch ID sensor cable to the back side of the display panel. Use an opening pick to gently separate the adhesive holding the home/Touch ID sensor cable to the back side of the display panel. Use an opening pick to gently separate the adhesive holding the home/Touch ID sensor cable to the back side of the display panel.
  • Use an opening pick to gently separate the adhesive holding the home/Touch ID sensor cable to the back side of the display panel.
A l'aide d'un médiator, coupez soigneusement l'adhésif qui maintient la nappe du capteur home/Touch ID sur le dos du panneau d'écran.
[* black] UsingUse an opening pick, carefully slice throughpick to gently separate the adhesive holding the home/Touch ID sensor cable to the back side of the display panel.
