Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 6 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 7
Étape 7
Remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
  • Remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
  • To reinstall, first feed the cable through the hole in the front of the display.
  • Your replacement part may come with an extra Y000 screw already installed right of the Home Button. Remove the unnecessary screw so that you can reinstall the home button bracket.
Retirez l'ensemble capteur home/Touch ID.
[* black] Remove the home/Touch ID sensor assemblyassembly by lifting it through the front side of the display.
[* icon_reminder] To reinstall, first feed the cable through the hole in the front of the display.
[* icon_reminder] Your replacement part may come with an [https://d3nevzfk7ii3be.cloudfront.net/igi/O3Q1JrSKUBugrqhN|extra Y000 screw|new_window=true] already installed right of the Home Button. Remove the unnecessary screw so that you can reinstall the home button bracket
