Traduction de l’étape 1
Étape 1
Remove the first set of two screws from the lens outer casing using a Phillips #00 screwdriver.
- | [* black] Remove the first set of ***two*** #00 phillips screws from the lens outer casing |
- | [* black] The first set of screws are located on the front and bottom of the lens casing |
- | [* icon_note] ''Pull the screws out and set them aside so as not to lose them'' |
+ | [* red] Remove the first set of two screws from the lens outer casing using a Phillips #00 screwdriver. |
+ | [* icon_note] The first set of screws is located on the front and bottom of the lens casing. |
