Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Traduction de l’étape 15
Étape 15
Secure the circuit board with a vise or a "helping hands" tool. Angle the board such that you can easily access the solder pads. Wear safety goggles.
If possible, use a tip with the largest surface area that can still fit between the solder joint.
Turn on your soldering iron. If your soldering iron has temperature control:
Set it to 350 °C (~650 °F) if you're using leaded solder
Set it to 375 °C (~700 °F) if you're using lead-free solder
