Aller au contenu principal
Comment souder et dessouder des connexions
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 1
Étape 1
How To Solder and Desolder Connections, Safety first: étape 0, image 1 de 2 How To Solder and Desolder Connections, Safety first: étape 0, image 2 de 2
Safety first
  • Before you begin soldering, note the following safety precautions:
  • Never solder on devices that are powered on or plugged in. Unplug, turn off, and remove power sources before soldering.
  • Don't solder directly to hard-shell lithium-ion batteries (such as 18650 cells). The heat from the soldering iron will damage the battery internals. Use a battery spot welder instead.
  • Be extremely careful if you're soldering/desoldering lithium-polymer battery wires! You can easily short the battery with solder or your tools, resulting in battery damage and a fire hazard. Follow these precautions:
  • Drain the battery below 25%. This reduces the battery's ability to start a fire if it was short-circuited.
  • Work with one wire at a time to avoid short circuits. Use tweezers and hold each wire to control its movement and ensure it doesn't short. If you're desoldering a battery from a circuit board, use flush cutters to cut each wire one-at-a-time to isolate the battery before you desolder the wires.
  • Whenever possible, create an indirect path by soldering connectors onto the battery and the circuit board. This reduces the chance of an unintentional short.
Avant de commencer à souder, tenez compte des mesures de sécurité suivantes :
Ne soudez jamais sur des appareils sous tension ou branchés. Débranchez, éteignez et retirez les sources d'alimentation avant de souder.
Ne soudez pas directement sur des batteries lithium-ion à coque dure (telles que les cellules 18650). La chaleur du fer à souder cassera les composants internes de la batterie. Utilisez plutôt une soudeuse à point pour batteries.
Soyez extrêmement prudent lorsque vous soudez/dessoudez des raccords de batteries au lithium-polymère ! Vous pouvez facilement court-circuiter la batterie avec la soudure ou vos outils, ce qui endommagerait la batterie et présenterait un risque d'incendie. Suivez les précautions suivantes :
Déchargez la batterie en dessous de 25 %. Cela réduit la capacité de la batterie à déclencher un incendie en cas de court-circuit.
Travaillez avec un seul raccord à la fois pour éviter les courts-circuits. Utilisez une pincette et tenez chaque fil pour contrôler son mouvement et vous assurer qu'il n'y a pas de court-circuit.
Si vous dessoudez une batterie d'un circuit imprimé, utilisez une pince coupante pour couper chaque fil un par un afin d'isoler la batterie avant de dessouder les fils.
Dans la mesure du possible, créez un chemin indirect en soudant des connecteurs sur la batterie et le circuit imprimé. Vous réduirez ainsi le risque de court-circuit involontaire.
