Traduction de l’étape 3
Étape 3
Remove the battery
Slide an opening pick up the side of the battery to break apart any remaining adhesive.
Lift the battery out of the case.
If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
+ | [title] Remove the battery |
[* black] Slide an opening pick up the side of the battery to break apart any remaining adhesive. | |
[* black] Lift the battery out of the case. | |
- | [* icon_caution] Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery. |
+ | [* icon_caution] Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery. |
+ | [* black] If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate. |
[* icon_reminder] To install a new battery and adhesive, [guide|123541|follow this guide|new_window=true]. |
