Aller au contenu principal
Well Pump Pressure Switch Replacement
Anglais
Français
Traduction de l’étape 2
Étape 2
Well Pump  Pressure Switch Replacement: étape 0, image 1 de 3 Well Pump  Pressure Switch Replacement: étape 0, image 2 de 3 Well Pump  Pressure Switch Replacement: étape 0, image 3 de 3
  • WARNING: The switch is supplied with 220V so one has to be careful not to get zapped. The first thing before doing anything is to flip the breaker to the pump switch and check it with a meter to ensure it is off.
  • Remove the small nut from the cover to gain access to the switch.
  • With the cover removed, check for power across the switch from supply lines L1 and L2 (Blue marker). Ensure that there is 0 volt.
Insérez ici votre traduction
