Aller au contenu principal
Well Pump Pressure Switch Replacement
Anglais
Français
Traduction de l’étape 3
Étape 3
Well Pump  Pressure Switch Replacement: étape 0, image 1 de 3 Well Pump  Pressure Switch Replacement: étape 0, image 2 de 3 Well Pump  Pressure Switch Replacement: étape 0, image 3 de 3
  • Close off the water supply to the dwelling by turning the gate valve to the right side.
  • Next drain the tank and the supply line by opening the valve. Each installation could be different, depending on ow and where it is installed. Any installation should have a shut-off valve and a drain valve somewhere before entering the dwelling.
  • Loosen the 4 screws that hold the wires to the switch
  • The ground screw on the bottom of the switch shares the ground from the supply line and from the pump. Remove those as well.
  • With the wires removed from the switch and the water line drained, remove the switch from the nipple attached to the check valve. Use a suitable wrench like an adjustable or in this case a pipe wrench
Insérez ici votre traduction
