Aller au contenu principal
Well Pump Pressure Switch Replacement
Anglais
Français
Traduction de l’étape 4
Étape 4
Well Pump  Pressure Switch Replacement: étape 0, image 1 de 3 Well Pump  Pressure Switch Replacement: étape 0, image 2 de 3 Well Pump  Pressure Switch Replacement: étape 0, image 3 de 3
  • It became immediately obvious that the nipple was almost completely corroded of the check valve. It broke off while attempting to remove the pressure switch.
  • After the use of a couple of choice words and cleaning the damage on check valve, it turned out that the thread was not damaged.
  • In this case the nipple needs to be replaced as well. The bottom one is the corroded one and the top is the new one.
  • Corrosion and debris on the inside of the nipple show that it is almost entirely occluded.
Insérez ici votre traduction
