If pedaling forwards with your bike has no affect, as in your bicycle is not propelled forward as expected, you've come to the right place. Read on for common causes and solutions to get back your pedal power.
Gear Too Low
Most commonly this occurs when a bicycle with a triple chainring (three gears in front) gets shifted accidentally into the smallest cog. Take a look at the gearing on your bike, and if the chain is sitting on the smallest cog in the front and/or the biggest cog on the back, shifting the bike into a different gear may solve your problem.
Be sure to shift the gears while you're pedaling the bike, however slowly. Shifting the bike while stationary can damage your derailleurs!
Chain Came Off
Check that the chain is still properly seated on both the front chainring and the rear cogs. Certain circumstances can cause the chain to slip off the gears and break the system. If your chain isn't too tangled up, it should be relatively simple to set it back on the gears in the front and rear—just be prepared to get your fingers dirty. See the Chain Connecting Guide for help on reconnecting your chain.
If your chain comes off regularly, there's likely a larger underlying problem at play. Use our Chain Keeps Coming Off page to get your chain secured.
Chain Broken
Your bicycle chain is vital to keeping you moving. If your chain breaks, it will typically become snapped. This can commonly occur when it the chain is under too much tension, gets bent, or becomes worn.
If you identify this to be your problem, stop riding and flip your bike over.
0 commentaires
