Wiki réalisé avec l'aide d'étudiants
Une formidable équipe d’étudiants de notre programme éducatif a créé ce wiki.
Won’t charge
Charging light is not turning on when vacuum is turned off
Charger not working properly
Please ensure the vac is turned off. First check if the charger is plugged in properly into the wall outlet and no breakers are tripped. Make sure the charger wire is undamaged and properly connected completely into the vacuum. If the charging light still does not turn on, request a warranty charger replacement or order a replacement charger
Battery not functioning
If the charging light never shows fully charged after an entire day, the battery is not charging, try reconnecting and turning the vacuum on and off. If the battery still won't charge or only charges intermittently, a replacement may be required.(!!!link to guide here)
Connection to minivac broken
If the minivac charges correctly when disconnected to the stick, look at the “minivac won't connect” troubleshooting
Low Suction
The vacuum is not sucking as much as it usually does
Battery not charged
Make sure the battery is fully charged while you use the device for full suction. If there is low suction power with a fully charged battery, a replacement may be required.(!!!link to guide here)
Filter/Dustbin is full
Make sure the flow from the stick to the minivac is not obstructed with large bits of material. Be sure to clean your filter and empty your dustbin after each use.
Brush not spinning
The brush or beater bar is not spinning when the mode is activated while the mini vac is connected
Connection to minivac faulty
If you use the switch on the stick and the vacuum does not turn on, the switch or the connection to the minivac is faulty. Confirm the device charges through the stick portion, if it can there may be a problem with the switch or brush itself. If the vacuum cannot charge, look at the “minivac won’t connect” troubleshooting
Switch broken
If no sound is produced near the brush when it turned on, the switch could be broken. Check with your warranty or replace your switch for the stick portion.(!!!link to guide here)
Belt/Brush not functioning properly
Make sure the vacuum is turned off before troubleshooting. Check that there is no material clogging the vacuum or the brush and belt assembly. Follow our brush or belt replacement guides in order to remove and clear debris from the vacuum. If either the belt or brush seem worn down or broken, follow the replacement guide.(!!!link to guide here)
Brush motor is not working
If the connection to the minivac is secure, both the brush and the belt are working correctly, and the switch is working, the brush motor could be broken. If there is a humming or clicking sound when the belt and brush is removed, this is a clear sign of the brush motor being faulty. Follow our brush motor replace guide or avoid using the brush function to prevent further damage.(!!!link to guide here)
Vacuum won't turn on
The vacuum will not turn on while it’s plugged in. If the stick switch won't turn on the vaccum, look at the “minivac won't connect” section
Battery is not working
Make sure the battery is fully charged, with the vacuum turned off while charging.
After many cycles of use or after intense wear, the battery may lose charge over time or wont function at all. Contact Black and Decker for warranty coverage or replace the battery(!!!link to guide here) in order restore function.
Suction motor is not spinning
If an audible clicking or no movement at all is happening when switched on, but the power light is on, the suction motor or internal wiring may be broken. Do not turn on the vacuum until the motor is replaced(!!!link to guide here) to prevent further damage.
Minivac won't connect to stick portion
If the minivac functions correctly but the switch or charging from the main vacuum is not or only functions intermittently the connection between the two may be broken
Bad contacts to minivac
Make sure the metal pads and pins between the minivac and the stick are touching properly. A brush with no water may be used to clean the contacts (those metal pads and pins) in order to remove corrosion. If there is a good connection but the switch on the stick portion does not do anything, the switch or internal wiring if the stick portion may be broken.
Broken switch on the stick
If the switch is not working, try cleaning the area around it and the switch itself with electrical contact cleaner. A replacement of the switch may be needed.(!!!link to guide here) A temporary solution is to turn on the minivac with its own switch but use it within the stick portion, this way the vacuum is still being used with only a little loss in function.
Battery depletes quickly after short usage
The battery has little to no capacity or cannot run at full power for long
Battery not fully charged
Make sure the charging light is on when you plug in the vacuum for charging. Give the battery a full day to charge in order to make sure its fully charged. Make sure the vacuum is off while charging. If the vacuum still does not function, the battery has lost capacity.
Battery lost capacity
Over time, the battery may lose capacity naturally from repeated uses and will eventually need to be replaced. When this happens, you need to make sure you can get a warranty replacement battery or replace the battery(!!!link to guide here) in order to restore function.
27 commentaires
The 3 battery charging lights are continuoskt fkashing all at the same tim dies anyone know why this is please
andrew david jenkins - Réponse
I've just received mine from Amazon. Battery lights are flashing rapidly. Manual says it means faulty battery, think I'm going to have to return it. Very annoying.
Doug Short - Réponse
Exactly the same with mine...just got it and have not even sucked up a crumb and the charge lights are flashing rapidly....not impressed with this product...5 negative x's from me.
Ken U -
After the battery it’s fully charged and the vacuum is working suddenly it’s stop working and the battery light starts blinking, why ? and this happens only when it’s fully charged
Ahed - Réponse
Where can I buy a replacement battery? Black and Decker’s website links to ServiceNet for parts, but they do not list the battery.
Robert Inglesby - Réponse
