Wiki réalisé avec l'aide d'étudiants
Une formidable équipe d’étudiants de notre programme éducatif a créé ce wiki.
Does Not Turn On
Device does not turn on when power button is pressed
Faulty Power Outlet
If the outlet you're using is damaged then it will not power the projector. Try plugging into a different spot.
Power cable is broken
If the cable used to plug in device is damaged it will likely not transfer power. Try using a different cable if you have one.
Power button isn't responding
The power button either doesn't click or clearly doesn't send a signal when pressed. Open the device and check to make sure the connections inside are undamaged.
Main PCB Board Is Broken
If the buttons are functioning but nothing happens when clicked, the main PCB board might be broken. Open the device and replace the board.
Device Is Too Hot When Running
When on for a time the device feels too hot
Projector Has Been On For Too Long
Hold the power button and shut down device. This will give it time to cool and let it fully reset.
Insides Cluttered With Dust
Open the back panel and make sure the internals are clean and undamaged. If there is a lot of dust it will cause overheating and be a fire hazard.
Fan Is Not Running
Open the device and check to make sure the fan is fully clean and functional. If it is clearly not running correctly, it may need to be replaced.
No Noise Coming From Device Speaker
The speaker in the projector has stopped working and no noise is coming from it
Connection Cable May be Damaged
Take a look at the cable connecting the projector to your computer. It may not be transferring audio correctly. Try using a different cable.
Internal Connections Damaged
Open the device and take a look at the connections and ribbon cables inside. Make sure they are fully connected and undamaged.
Speaker Is Broken
If everything is functional but the noise is still distorted/not coming out, you may have to replace the speaker itself. Open the device and replace the speaker.
Bulb Not Functioning
The device is on, but no light is coming out
Device has been on too long
Hold power button to power down device, then turn back on to reset it. This will reset the internals and give it a chance to rest.
Bulb is broken
If everything else is functional but there is still no light or image coming out, the bulb itself may be damaged or fried. Open the top and replace the device's bulb.
Device is Lagging
The device is clearly running slower than it should be
Device has been on for too long
Hold power button and shut down device to reset it. Let it stay for a few minutes to fully shut down. If problem persists, proceed to next step.
Air Filter Dysfunctional
Open up the side panel and check the dust filter. Clean it if dirty or replace if it's damaged. Often times bad filtration can lead to lagging and devices running slower than they should.
0 commentaires
