Doesn't turn on
No matter what you do, the alarm clock will not turn on.
Power cord is plugged in
Check to make sure the power cord is plugged in. If it is, make sure the display light is on. If the display is not on and the power cord is plugged in, the display or the power cord is faulty. Replace or repair the LCD display using this guide or the power cord using this guide.
Battery is faulty
If the display only turns on when the power cord is plugged in, then the battery is faulty. Replace the battery or the battery wires using this guide.
Music will not play
The unit will not produce any music.
On/Off/Music/Alarm tab is not switched to Music
Check to make sure the alarm clock is switched to the Music tab. If it is not, flip the switch to Music.
Volume is turned down
If the alarm clock is switched to the Music tab and still doesn't play, make sure the volume is turned up. If you still don't have music, the speaker may be faulty. Replace the speaker using this guide. If the On/Off/Music/Alarm switch does not work, replace or clean it using this guide.
Sound is distorted
Sound coming from the alarm clock sounds funny.
Volume is too high
Check to make sure your volume is not excessively turned up. If it is, turn it down until the sound quality improves.
Tuning dial is not precisely set to your desired station
If the sound is still distorted, make sure the tuning dial is set to the exact station you selected. If the tuning dial is slightly off your desired station, the sound quality degrades. If the tuning dial does not work, replace or clean it using this guide.
Speaker is damaged
If the sound quality does not improve, the speaker is faulty. Ensure the speaker is not obstructed, then repair or replace the speaker using this guide.
Alarm clock is hot
Alarm clock gets hot after extended periods of time.
Turn the alarm clock off
If the alarm clock is hot, turn it off to cool down. The unit may get hot from overuse, playing music at a high volume, or after running for extended periods of time.
Increased heat is normal with operation
The increased heat of the unit is normal with operation. Ensure air flow to alarm clock is sufficient by eliminating anything draped over the alarm clock or anything else impeding the air flow.
Alarm does not work
I set the alarm, but it did not work.
Volume is down or the unit is off
Check to make sure the volume is turned up and the unit is not turned off. If the volume is low, turn it up, so your alarm will have volume. If you do not hear any static or music, the speaker is faulty. Use this guide to repair or replace it.
A.M./P.M. setting is incorrect
Check to make sure the alarm is set to the desired A.M./P.M. setting. If it's not, change the setting to your desired time of day using the A.M./P.M. switch.
If the alarm still does not work, the On/Off/Music/Alarm switch is faulty. Use this guide to repair or replace it.
5 commentaires
How do I turn the alarm off. Thanks
Ajoy Adhikari - Réponse
how do you set the time
Julianne Navar - Réponse
My clock is frozen always showing the same leds on like a “IP:G8“ and no matter wich button i press nothing happens
cainaalvesandrade - Réponse
I can’t turn the radio off! None of the dials work for tuning the radio :(
stagar98 - Réponse
How do I turn the radio off - none of the dials work!
stagar98 - Réponse
