Wiki réalisé avec l'aide d'étudiants
Une formidable équipe d’étudiants de notre programme éducatif a créé ce wiki.
This troubleshooting page will assist you in diagnosing problems with the Lenovo Yoga 910-13IKB.
Laptop Doesn’t Charge When Plugged In
The laptop does not charge when plugged in.
Faulty Power Adapter
Make sure that the power adapter is fully plugged in . If the computer is plugged in and shows no sign or response, the adapter may be broken. Consider purchasing a replacement adapter.
Battery Loses Charge Quickly
The battery runs out very fast or does not respond to being plugged in.
Faulty Battery
If you are certain that the power adapter is working properly, or the laptop will only power on when plugged in, then the battery is faulty. A guide for replacing the battery can be found here.
Laptop Doesn’t Connect to WiFi
The laptop doesn’t connect to WiFi.
Laptop is in Airplane Mode
Make sure that the laptop is not in airplane mode. Go to the laptop’s settings and ensure that airplane mode is off and WiFi is turned on.
Faulty Router
If you have checked the settings mentioned above, it is possible that the WiFi router needs to be restarted. Power off and remove the cables from the router. Wait a moment, and plug everything back in and turn the router on.
Fingerprint Sensor Not Working Properly
The fingerprint sensor is not recognizing your finger.
Finger Hasn’t Been Registered
Make sure that you are using the same finger that you used to set up the fingerprint recognition feature. The sensor may be working as intended, but the laptop will only recognize fingerprints that have previously been set up. Windows has support for multiple fingerprints, so you can add a few of your fingerprints to expand functionality.
The Sensor is Dirty
Over time, the sensor may become dirty or greasy. Be sure to wipe the sensor with a microfiber cloth regularly to avoid this problem.
Broken Sensor
If the sensor no longer properly recognizes your finger, the sensor may be faulty. A guide for replacing the sensor can be found here.
Speakers Are Not Working Properly
The speakers sound muffled, distorted, or are not making noise at all.
Debris in the Headphone Jack
Check the laptop’s audio jack to make sure that there is no debris that might interfere with audio play. Clear the jack of any foreign objects.
The Speakers Have Been Muted in the Settings
Open the sound settings by clicking on the sound icon in the bottom right portion of the taskbar and select “Open Sound settings.” Select “Choose your output device” and make sure the volume is not muted.
The Speakers are Distorted or Muffled
The speakers may be blown out and need replacing. For information on how to replace the laptop’s speakers, visit the guide here.
3 commentaires
how to fix my display appear horizontal line, tq
Mr. G - Réponse
So I’m trying to fix this lap top the light turns on the side where you plug but the left side and key board only turn on for a sec and then back off over and over. nothings working… I noticed on the Wi-Fi card the white wire broke off the chip so I took it off and then touch it on a ground screw on the mother board and the left light stays solid finally but not screen or keyboard light on though.
Francisco Bayardo, Jr. - Réponse
Common fault is also the USB C daughter board and even the power button board.
If it charges but fails to turn on, power button board can be the culprit.
If it doesn't charge consistently (like it will only power on or charge if you remove power for some time and plug back in), it may be a sign the power in daughter board is bad.
If it powers on but doesn't display, pretty much usually the motherboard - but just press the caps lock key to make sure it's not posting - to be safe.
Sean Sullivan - Réponse
