Wiki réalisé avec l'aide d'étudiants
Une formidable équipe d’étudiants de notre programme éducatif a créé ce wiki.
Trimmer failing to activate
The trimmer will not turn on, regardless of what you do.
Dead battery
If you have not turned your trimmer on in a while or used it recently, the battery may be dead and just needs to be replaced.
Broken motor
If you happened to drop your trimmer and it no longer turns on, there is a good chance the motor broke. A quick way to tell if the motor is broken, shake your device. If you hear any rattling then it is more likely to be the motor. Fixing this requires you to open up your device, so it is better to check the other options first.
Corroded or broken battery leads
After long term usage, the battery may corrode and in some cases the leads can break off. To check this, simply twist the bottom off and look at the leads (the leads are the silver metal pieces where the battery is held). If they are corroded, there will be a white residue where the battery contacts the leads. Removing the corrosion is pretty simple since you can scrape it off. (Note: DO NOT TOUCH CORROSION WITH YOUR BARE SKIN). Using a solution such as Caig DE-oxit D5 on a cotton swab is another good way to clean a corroded terminal.
Blade is not spinning
After flipping the switch, the trimmer blade does not rotate.
Broken motor shaft
If the blade snags or suddenly gets jammed, the motor shaft can snap, preventing the blade from spinning. If you remove the black trimmer cap, the motor shaft juts out of the top of the device. Give it a gentle tug and if it pops out then it is broken and will need to be replaced.
Motor stuck/not spinning due to corrosion
If the motor has been turning slowly, even with a new battery, or it has stopped turning all together, it is possible the motor has some corrosion. While the motor cannot be seen, it is internal to the body, WD-40 can be sprayed liberally up in to the body, soaking the internals. Drain the residual WD-40, blow it out with compressed air if available.
The trimmer is on and the blade is spinning but is not cutting anything.
Dull or broken blade
After long term usage, the blade can start to wear down or even break entirely. To check if the blade is broken, remove the trimmer cap and pull the blade out of the cap. If it is broken, the blade will have noticeable pieces missing from the top. The blade will have to be replaced for this fix.
Power switch jam
The power switch is incredibly hard to flip or will not flip at all.
Clogged switch
After long term usage, the power switch can get jammed, making it really difficult to flip. Over time debris can build up under the switch causing a jam. For this fix you will have to open up your device and remove the switch.
Switch leads corroded/broken
After long term usage, the leads connecting the switch to the battery can corrode or even break off. Just like the battery leads, the leads connecting the switch to the rest of the device can corrode or break. Checking this will require you to open up your device.
Vortex Cleaning System jammed
Water does not flow through the top portion for cleaning your trimmer.
Water pass through ring jammed
After long term usage, the ring at the top can get jammed, preventing you from turning it for cleaning. To check for debris, remove the trimmer cap and look inside the top of the device.
Water pass through ring broken
If your trimmer falls, the ring you turn to let water through can break, preventing you from cleaning your trimmer properly. Inspect the ring and check for cracks. If the ring is cracked or missing, you will have to replace it.
18 commentaires
I have taken good care of my Panasonic nose trimmer none of the above applies to the problems I'm having other than it does not work. Where can I have it repaired as I'm very pleased with my product
Mollyskip - Réponse
Lasts 2 years. All of them fail but they are the best. Buy new on. Repair cost more than replace
Kenneth Levy -
I want my Panasonic nose trimmer to be repaired. I'm very pleased with it. I've changed the batteries I've always taken good care of it.
Mollyskip - Réponse
Mine wouldn't power on w fresh battery. Turns out the connector in battery cover had depressed and was no longer making a connection. I pried it up a bit and all is well. I'll store it on its side from now on in case the weight of the battery pressed the connector down too much.
Billy Jackson - Réponse
The first two Panasonic nose trimmers I bought were awesome and lasted a year or more. The last two I have purchased have had weak motors. I have always taken very good care, cleaning after every use, which is about once a week. This last one I bought in August, 2019 is so weak it is useless. It has been used 5 times. I replaced the battery and it does not affect the power. The prior one lasted four months, but I thought it might be a lemon. Two in a row? There is definately a problem.
I sure wish you guys would fix this issue and let me know when you have. Until then, I will try to find another that works as well as yours used to.
Denise Ballings - Réponse
