Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tutoriels de réparation et assistance pour la deuxième génération de Honda Insight.
I got an error code p1448
I got an error code p1448. Indicate ipu motor unit. Help
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
2 commentaires
How to clear the air inlect
par Partager
Hi, do you have a solution to this? Same issue on a 2010 Honda civic IMA hybrid
par Partager
Ajouter un commentaire
2 Réponses
Solution retenue
Rames, Info. found at Insightcentral. Older insights 00-04, code P1448 may set if the batteries inlet duct or exhaust duct get blocked. If not blocked check the battery fan. If the fan works, the battery may be at fault and needs to be rebuilt or replaced. Check the attached links,instruction and guides, Good luck.
http://www.insightcentral.net/forums/pro...
http://www.crzforum.com/forum/engine-bat...
Indice 3
Réponse la plus utile
@ramesh77 you correctly found that P1448 is a Intelligent Power Unit (IPU) Module Fan Problem. Follow the manuals troubleshooting flowchart to determine where the error originates from and repair as required.
Indice 4
1 commentaire:
Is there a similar troubleshooting process for a 2011 civic hybrid ? I get a P1448 code and the fan runs full blast for a few seconds after shutdown. I dont see how it would be a fan problem since it works. I did the steps for verifying the voltage at the fan connector. Where do i go next?
par Partager
Ajouter une réponse
rames sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 56
Total : 15,374
