Computer will not boot while RAM is in
I have a 2011 macbook pro that will not boot. It tries to start up but then the fans stop and nothing happens. If I remove the RAM then the fans will keep spinning but it the computer beeps until I shut it off because there are no RAM sticks in. I have a feeling it is the logic board but really don't know if it would be worth it to replace it. Any ideas on how I could fix this?
Thanks,
Devin
8 commentaires
did you try both slots seperately
par daniel
Did it ever boot for you? Did something happen to it?
par mayer
Can you give us some background info. Was it working with this RAM, or did you upgrade it? If you upgraded try going back to the other RAM modules.
par Dan
I have tried both slots seperately and that does not work. The computer had the RAM upgraded and it worked for over a year. Then it randomly stopped working and was giving the beeping like the RAM was the problem. I never got a round to fixing it and now that I have it doesn't beep at all unless the RAM is completely removed. This make me think it has to do with how the ports that the RAM is seated in and that is connected to the logic board.
par Devin Ford
What is the beep pattern
par Dan
Voir 3 commentaires en plus
