Aller au contenu principal
HTC Vive Cosmos Fan Replacement
Ce dont vous avez besoin
  1. HTC Vive Cosmos Fan Replacement, Remove the facerest: étape 1, image 1 de 3 HTC Vive Cosmos Fan Replacement, Remove the facerest: étape 1, image 2 de 3 HTC Vive Cosmos Fan Replacement, Remove the facerest: étape 1, image 3 de 3
    • Pull the bottom of the facerest straight away from the Vive Cosmos to unclip it from the Vive.
    • With the bottom unclipped, pull the top of the facerest away from the Vive to remove it.
  2. HTC Vive Cosmos Fan Replacement, Release the faceplate switch: étape 2, image 1 de 2 HTC Vive Cosmos Fan Replacement, Release the faceplate switch: étape 2, image 2 de 2
    • Use your finger to push the sliding faceplate release switch, sitting to the left of the lenses, toward the bottom of the Vive.
  3. HTC Vive Cosmos Fan Replacement, Remove the faceplate: étape 3, image 1 de 2 HTC Vive Cosmos Fan Replacement, Remove the faceplate: étape 3, image 2 de 2
    • While holding the switch in the bottom position, pull the faceplate straight up and away from the front of the Vive.
    • Remove the faceplate.
  4. HTC Vive Cosmos Fan Replacement, Unscrew the focus knob: étape 4, image 1 de 1
    • Use a T5 Torx driver to remove the 4.1 mm long screw securing the focus knob.
  5. HTC Vive Cosmos Fan Replacement, Remove the focus knob: étape 5, image 1 de 2 HTC Vive Cosmos Fan Replacement, Remove the focus knob: étape 5, image 2 de 2
    • Slide the focus knob out of the plastic housing, off of the focus rod, and remove it.
  6. HTC Vive Cosmos Fan Replacement, Unplug the audio connector: étape 6, image 1 de 3 HTC Vive Cosmos Fan Replacement, Unplug the audio connector: étape 6, image 2 de 3 HTC Vive Cosmos Fan Replacement, Unplug the audio connector: étape 6, image 3 de 3
    • Twist the 3.5 mm audio connector counter-clockwise slightly and slide its cable out from under the plastic retaining clip.
    • Lift the audio connector straight up to unplug it.
  7. HTC Vive Cosmos Fan Replacement, Unscrew the LCD and motherboard assembly: étape 7, image 1 de 1
    • Use a T5 Torx driver to remove the three 4.1 mm long screws securing the LCD and motherboard assembly.
  8. HTC Vive Cosmos Fan Replacement: étape 8, image 1 de 2 HTC Vive Cosmos Fan Replacement: étape 8, image 2 de 2
    • Gently peel up the stickers on either side of the front of the Vive. If possible, keep the stickers intact and reuse them.
  9. HTC Vive Cosmos Fan Replacement: étape 9, image 1 de 1
    • Use a T5 Torx driver to unscrew the screws securing the upper component cover and the LCD and motherboard assembly:
    • Sixteen 4.1 mm long screws
    • One captive screw
    • This screw is covered by a sticker. Poke your driver through the sticker to access the screw.
    • Two 4.1 mm long screws
    • These screws are covered by stickers. Poke your driver through the stickers to access the screws.
  10. HTC Vive Cosmos Fan Replacement, Remove the microphone: étape 10, image 1 de 1
    • Remove the microphone cover from the bottom edge of the headset.
  11. HTC Vive Cosmos Fan Replacement, Separate the microphone adhesive: étape 11, image 1 de 2 HTC Vive Cosmos Fan Replacement, Separate the microphone adhesive: étape 11, image 2 de 2
    • Slide an opening pick under the microphone to separate the adhesive securing it to the Vive.
    • If this is difficult, use a heated iOpener, hair dryer, or heat gun to apply heat to adhesive.
  12. HTC Vive Cosmos Fan Replacement, Remove the upper component cover: étape 12, image 1 de 3 HTC Vive Cosmos Fan Replacement, Remove the upper component cover: étape 12, image 2 de 3 HTC Vive Cosmos Fan Replacement, Remove the upper component cover: étape 12, image 3 de 3
    • Angle the bottom end of the upper component cover away from the front of the Vive.
    • Pull the upper component cover away from the front of the Vive and remove it.
  13. HTC Vive Cosmos Fan Replacement, Remove the camera connector covers: étape 13, image 1 de 3 HTC Vive Cosmos Fan Replacement, Remove the camera connector covers: étape 13, image 2 de 3 HTC Vive Cosmos Fan Replacement, Remove the camera connector covers: étape 13, image 3 de 3
    • Slide the camera connector covers on either side of the LCD and motherboard assembly away from the center off of the assembly and remove them.
  14. HTC Vive Cosmos Fan Replacement, Disconnect the cameras: étape 14, image 1 de 3 HTC Vive Cosmos Fan Replacement, Disconnect the cameras: étape 14, image 2 de 3 HTC Vive Cosmos Fan Replacement, Disconnect the cameras: étape 14, image 3 de 3
    • Peel the tape over the right camera connector back enough to access the camera's ZIF connector underneath.
    • Repeat the same process to peel back the tape over the left camera ZIF connector.
  15. HTC Vive Cosmos Fan Replacement: étape 15, image 1 de 3 HTC Vive Cosmos Fan Replacement: étape 15, image 2 de 3 HTC Vive Cosmos Fan Replacement: étape 15, image 3 de 3
    • Use the point of a spudger to flip up the small locking flap securing the right camera cable ZIF connector.
    • Carefully slide the camera connector cable straight out of its socket on the motherboard.
  16. HTC Vive Cosmos Fan Replacement: étape 16, image 1 de 2 HTC Vive Cosmos Fan Replacement: étape 16, image 2 de 2
    • Use the point of a spudger to flip up the small locking flap securing the left camera cable ZIF connector.
  17. HTC Vive Cosmos Fan Replacement, Disconnect the microphone: étape 17, image 1 de 1
    • Peel the yellow tape off of the microphone connector.
  18. HTC Vive Cosmos Fan Replacement: étape 18, image 1 de 2 HTC Vive Cosmos Fan Replacement: étape 18, image 2 de 2
    • Use the point of a spudger to flip up the small locking flap securing the microphone cable ZIF connector.
  19. HTC Vive Cosmos Fan Replacement: étape 19, image 1 de 3 HTC Vive Cosmos Fan Replacement: étape 19, image 2 de 3 HTC Vive Cosmos Fan Replacement: étape 19, image 3 de 3
    • Carefully slide the microphone connector cable straight out of its socket on the motherboard.
    • With the cable out of its socket, slide the cable toward the bottom of the Vive and out of its clip on the LCD and motherboard assembly.
    • Take care not to crease or tear the cable while you're moving it.
  20. HTC Vive Cosmos Fan Replacement, Remove the LCD and motherboard assembly: étape 20, image 1 de 2 HTC Vive Cosmos Fan Replacement, Remove the LCD and motherboard assembly: étape 20, image 2 de 2
    • Lift the LCD and motherboard assembly out of the headset.
    • The assembly is secured by clips around the edges. It may help to release the clips using a thin plastic tool, like an opening tool or a spudger.
  21. HTC Vive Cosmos Fan Replacement, Disconnect the LCD panels: étape 21, image 1 de 1
    • Use a T5 Torx driver to remove the four 2.9 mm long screws securing the LCD connectors.
  22. HTC Vive Cosmos Fan Replacement: étape 22, image 1 de 3 HTC Vive Cosmos Fan Replacement: étape 22, image 2 de 3 HTC Vive Cosmos Fan Replacement: étape 22, image 3 de 3
    • Use the flat end of a spudger to pry the LCD connectors straight up and out of their sockets on the daughterboard.
  23. HTC Vive Cosmos Fan Replacement, Remove the LCD frame assembly: étape 23, image 1 de 3 HTC Vive Cosmos Fan Replacement, Remove the LCD frame assembly: étape 23, image 2 de 3 HTC Vive Cosmos Fan Replacement, Remove the LCD frame assembly: étape 23, image 3 de 3
    • Gently pull the bottom edge of the midframe away from the bottom edges of the LCD frames to unclip the LCD frames from the midframe.
  24. HTC Vive Cosmos Fan Replacement: étape 24, image 1 de 2 HTC Vive Cosmos Fan Replacement: étape 24, image 2 de 2
    • Remove the LCD frame assembly from the midframe.
    • During reassembly, first seat the support rod in its slots in the midframe. Then gently press the rest of the LCD frame assembly into the midframe so that the bottom edges of the LCD frames clip into the midframe.
  25. HTC Vive Cosmos Fan Replacement, Disconnect the fan: étape 25, image 1 de 2 HTC Vive Cosmos Fan Replacement, Disconnect the fan: étape 25, image 2 de 2
    • Peel both black plastic stickers off of either side of the motherboard.
  26. HTC Vive Cosmos Fan Replacement: étape 26, image 1 de 3 HTC Vive Cosmos Fan Replacement: étape 26, image 2 de 3 HTC Vive Cosmos Fan Replacement: étape 26, image 3 de 3
    • Use the tip of a spudger to push one side of the the fan connector slightly out of its socket on the motherboard, then push on the other side of the connector. Continue alternating pressure on each side to gently ease the connector out of its socket.
    • Apply pressure parallel to the motherboard. Do not pry up on the connector.
  27. HTC Vive Cosmos Fan Replacement, Unscrew the heat sink and fan: étape 27, image 1 de 1
    • Use a T5 Torx driver to remove the screws securing the heat sink and fan:
    • One 8.5 mm long screw
  28. HTC Vive Cosmos Fan Replacement, Unstick the heat sink: étape 28, image 1 de 1
    • Remove the heat sink bracket.
  29. HTC Vive Cosmos Fan Replacement: étape 29, image 1 de 2 HTC Vive Cosmos Fan Replacement: étape 29, image 2 de 2
  30. HTC Vive Cosmos Fan Replacement: étape 30, image 1 de 2 HTC Vive Cosmos Fan Replacement: étape 30, image 2 de 2
    • Slide the heat sink off of the fan. You do not need to completely remove it from the midframe.
  31. HTC Vive Cosmos Fan Replacement, Remove the fan: étape 31, image 1 de 2 HTC Vive Cosmos Fan Replacement, Remove the fan: étape 31, image 2 de 2
    • Slide an opening pick between the fan and the midframe.
    • If this proves difficult, apply heat to the midframe directly under the fan to soften the adhesive securing the fan.
  32. HTC Vive Cosmos Fan Replacement: étape 32, image 1 de 2 HTC Vive Cosmos Fan Replacement: étape 32, image 2 de 2
    • Use the opening pick to pry the fan away from the midframe.
  33. HTC Vive Cosmos Fan Replacement: étape 33, image 1 de 1
    • Lift the fan straight up from the midframe and remove it.
Adam O'Camb
Membre depuis le 04/11/15
197 105 Réputation
416 tutoriels rédigés
2 commentaires
Would the replacement fan also fit the same into a Vive Cosmos Elite Headset ?
Key Lo - Réponse
Both the vive cosmos elite and vive cosmos are almost identical. The only difference is the front panel which can be replaced on the vive cosmos to make it into the elite version.
Robert Kelso -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 19
Total : 972
