Aller au contenu principal
Lenovo IdeaPad S340-15IWL CMOS Battery Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, Back Panel: étape 1, image 1 de 2 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, Back Panel: étape 1, image 2 de 2
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement: étape 2, image 1 de 1
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, CMOS Battery: étape 3, image 1 de 3 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, CMOS Battery: étape 3, image 2 de 3 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, CMOS Battery: étape 3, image 3 de 3
    • Remove the circular CMOS battery on the far left side of the computer by lifting it with your finger or an opening tool.
    • This is only attached with adhesive, so it does not require extensive force.
  4. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement: étape 4, image 1 de 2 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement: étape 4, image 2 de 2
    • Unplug the bundled red and black wires connecting the CMOS battery to the side of the device.
    • Remove the CMOS battery from the laptop.
2 autres ont terminé cette réparation.
Kristen Gismondi
Membre depuis le 11/12/14
82 266 Réputation
200 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
17 275 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 135
Total : 1,621
