Aller au contenu principal
Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Back Panel: étape 1, image 1 de 2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Back Panel: étape 1, image 2 de 2
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: étape 2, image 1 de 1
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Wi-Fi Card: étape 3, image 1 de 2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Wi-Fi Card: étape 3, image 2 de 2
    • Pull up the black foam adhesive that covers the screw and connectors holding the Wi-Fi card in place.
  4. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: étape 4, image 1 de 2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: étape 4, image 2 de 2
    • Using an opening tool, lift up on the black and white coaxial cables on the Wi-Fi card and gently pull upward to unplug them.
    • When reconnecting the cables, be sure to match the colors to the arrows on the Wi-Fi card.
  5. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: étape 5, image 1 de 2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: étape 5, image 2 de 2
    • Remove the single 3 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
    • Gently lift the Wi-Fi card out of the computer.
Kristen Gismondi
Membre depuis le 11/12/14
82 305 Réputation
200 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 301 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 39
Total : 1,042
