Aller au contenu principal
Lenovo ThinkPad T480 Back Cover Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T480 Back Cover Replacement, External Battery: étape 1, image 1 de 2 Lenovo ThinkPad T480 Back Cover Replacement, External Battery: étape 1, image 2 de 2
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Back Cover Replacement: étape 2, image 1 de 3 Lenovo ThinkPad T480 Back Cover Replacement: étape 2, image 2 de 3 Lenovo ThinkPad T480 Back Cover Replacement: étape 2, image 3 de 3
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Back Cover Replacement, Back Cover: étape 3, image 1 de 2 Lenovo ThinkPad T480 Back Cover Replacement, Back Cover: étape 3, image 2 de 2
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 Back Cover Replacement: étape 4, image 1 de 3 Lenovo ThinkPad T480 Back Cover Replacement: étape 4, image 2 de 3 Lenovo ThinkPad T480 Back Cover Replacement: étape 4, image 3 de 3
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
3 autres ont terminé cette réparation.
Sarah Westberg
Membre depuis le 03/11/19
23 272 Réputation
70 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 295 tutoriels rédigés
2 commentaires
Dont forget the 3 clips in the removable battery area. No one mentioned those and I ended up breaking a clip and cracking the bottom cover of my T480... :(
Neccros - Réponse
Hey @neccros! Thanks for the feedback. I'm very sorry you cracked your bottom cover. I've updated the guide to incorporate your experience.
Sarah Westberg -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 53
30 derniers jours : 225
Total : 6,407
