Introduction
Use this guide to replace the RAM in your Lenovo ThinkPad T480s.
RAM (short for “random access memory”) provides temporary storage for a computer. RAM enables a computer to run with optimal speed and performance. Some signs of faulty RAM include the blue screen of death, sluggish performance, or random crashes and reboots.
This laptop is equipped for a maximum memory module capacity of 24 GB. You can add one 16 GB 2400MHz DDR4 SO-DIMM. You can run a RAM diagnostic tool to see if replacement is needed.
Before beginning this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
Ce dont vous avez besoin
Pull the plastic film back.
Push the clips outward to release the RAM stick.
The RAM stick will pop out at an angle. Pull the RAM stick out at the same angle.
