Aller au contenu principal
Lenovo ThinkPad T480s Speaker Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T480s Speaker Replacement, Bottom Cover: étape 1, image 1 de 2 Lenovo ThinkPad T480s Speaker Replacement, Bottom Cover: étape 1, image 2 de 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Speaker Replacement: étape 2, image 1 de 3 Lenovo ThinkPad T480s Speaker Replacement: étape 2, image 2 de 3 Lenovo ThinkPad T480s Speaker Replacement: étape 2, image 3 de 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Speaker Replacement: étape 3, image 1 de 2 Lenovo ThinkPad T480s Speaker Replacement: étape 3, image 2 de 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Speaker Replacement, Battery: étape 4, image 1 de 2 Lenovo ThinkPad T480s Speaker Replacement, Battery: étape 4, image 2 de 2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Speaker Replacement: étape 5, image 1 de 3 Lenovo ThinkPad T480s Speaker Replacement: étape 5, image 2 de 3 Lenovo ThinkPad T480s Speaker Replacement: étape 5, image 3 de 3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Speaker Replacement, Speaker: étape 6, image 1 de 3 Lenovo ThinkPad T480s Speaker Replacement, Speaker: étape 6, image 2 de 3 Lenovo ThinkPad T480s Speaker Replacement, Speaker: étape 6, image 3 de 3
    • Disconnect the speaker cable from the motherboard using a connector puller or spudger.
  7. Lenovo ThinkPad T480s Speaker Replacement: étape 7, image 1 de 2 Lenovo ThinkPad T480s Speaker Replacement: étape 7, image 2 de 2
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the right side.
  8. Lenovo ThinkPad T480s Speaker Replacement: étape 8, image 1 de 3 Lenovo ThinkPad T480s Speaker Replacement: étape 8, image 2 de 3 Lenovo ThinkPad T480s Speaker Replacement: étape 8, image 3 de 3
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the left side.
  9. Lenovo ThinkPad T480s Speaker Replacement: étape 9, image 1 de 3 Lenovo ThinkPad T480s Speaker Replacement: étape 9, image 2 de 3 Lenovo ThinkPad T480s Speaker Replacement: étape 9, image 3 de 3
    • Use the spudger to disconnect the hall sensor connector.
  10. Lenovo ThinkPad T480s Speaker Replacement: étape 10, image 1 de 3 Lenovo ThinkPad T480s Speaker Replacement: étape 10, image 2 de 3 Lenovo ThinkPad T480s Speaker Replacement: étape 10, image 3 de 3
    • Lift the speakers up.
    • Disconnect the cable speakers from the routing.
    • Remove the speakers from the system.
Sarah Westberg
Membre depuis le 03/11/19
23 330 Réputation
70 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 410 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 11
30 derniers jours : 46
Total : 1,350
