Introduction
If your Lenovo ThinkPad X1 Gen 1 Extreme (model number 20MF-000LUS) is having trouble charging, overheating, or not holding a charge, use this guide to replace the battery pack.
A battery in good condition will power the computer for 15 hour periods and charge to 80% capacity in an hour. A faulty battery will not charge properly and will lose power quicker than expected.
Before replacing the battery, refer to the trouble shooting page for the Lenovo ThinkPad Gen 1 Extreme to see if the problem is fixable without purchasing and installing another battery.
Please keep in mind that a swollen lithium ion battery is dangerous and read the page attached to the link before repair. Be sure to disconnect the computer from any power and turn the computer completely off. It is also important to be careful when removing the battery; any damage can easily make the computer not functional.
Ce dont vous avez besoin
Orient the laptop so that it is bottom up, and the trackpad is closest to you.
Unscrew the seven captive screws with a Phillips #00 screwdriver.
Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
Remove the back cover from the device.
Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
Use tweezers to peel the plastic cover off the connector.
Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
4 autres ont terminé cette réparation.
2 commentaires
Thank you so much for this illustration on how to take off the battery. I was like already stuck at just the screws not coming off. This helped immensely.
