Aller au contenu principal
Lenovo YOGA 730-15IKB Battery Replacement
Ce dont vous avez besoin
  1. Lenovo YOGA 730-15IKB Battery Replacement, Bottom Cover: étape 1, image 1 de 2 Lenovo YOGA 730-15IKB Battery Replacement, Bottom Cover: étape 1, image 2 de 2
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Battery Replacement: étape 2, image 1 de 2 Lenovo YOGA 730-15IKB Battery Replacement: étape 2, image 2 de 2
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Battery Replacement: étape 3, image 1 de 1
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Battery Replacement, Battery: étape 4, image 1 de 3 Lenovo YOGA 730-15IKB Battery Replacement, Battery: étape 4, image 2 de 3 Lenovo YOGA 730-15IKB Battery Replacement, Battery: étape 4, image 3 de 3
    • Disconnect the battery from the motherboard by gently pulling the battery cable using your fingers or a pair of tweezers.
    • Pull parallel to the battery, not straight up.
    • Unplug the cable gently as the eight wires on the connector are very small and delicate.
  5. Lenovo YOGA 730-15IKB Battery Replacement: étape 5, image 1 de 2 Lenovo YOGA 730-15IKB Battery Replacement: étape 5, image 2 de 2
    • Remove the four 4mm Phillips #1 screws securing the battery.
  6. Lenovo YOGA 730-15IKB Battery Replacement: étape 6, image 1 de 1
    • Lift the battery up and out of the chassis.
    • Handle the battery carefully. Touching the terminal may cause electric shock. Puncturing the battery may cause it to catch fire.
For optimal performance, after completing this guide, calibrate your newly installed battery.
8 autres ont terminé cette réparation.
Mathew Shaham
Membre depuis le 01/23/20
566 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S1-G6, White Winter 2020 Membre de l'équipe Cal Poly, Team S1-G6, White Winter 2020
CPSU-WHITE-W20S1G6
3 membres
27 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 35
30 derniers jours : 187
Total : 10,454
