Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Logitech G915 Wireless (Clicky) Battery Replacement
Ce dont vous avez besoin
  1. Logitech G915 Wireless (Clicky) Battery Replacement, Prepare your keyboard for disassembly: étape 1, image 1 de 3 Logitech G915 Wireless (Clicky) Battery Replacement, Prepare your keyboard for disassembly: étape 1, image 2 de 3 Logitech G915 Wireless (Clicky) Battery Replacement, Prepare your keyboard for disassembly: étape 1, image 3 de 3
    • Slide the power switch on the top edge of the keyboard to the OFF (left) position.
    • A red indicator should be visible beneath the switch.
    • Unplug all cables from the keyboard.
    • Lay the keyboard down with the feet facing up on a clean work surface.
    • If your work surface might scratch the keyboard, place a soft towel under it.
    Demander à FixBot
    Ajouter un commentaire
  2. Logitech G915 Wireless (Clicky) Battery Replacement, Remove the sticker: étape 2, image 1 de 2 Logitech G915 Wireless (Clicky) Battery Replacement, Remove the sticker: étape 2, image 2 de 2
    • The Logitech sticker hides two battery cover screws.
    • Heat an iOpener and lay it on the Logitech sticker for one minute.
    • Alternatively, you can use a hair dryer to heat the sticker. Make sure it's on the Low setting to avoid warping the plastic.
    Demander à FixBot
  3. Logitech G915 Wireless (Clicky) Battery Replacement: étape 3, image 1 de 3 Logitech G915 Wireless (Clicky) Battery Replacement: étape 3, image 2 de 3 Logitech G915 Wireless (Clicky) Battery Replacement: étape 3, image 3 de 3
    • If you don't want to remove the whole sticker, you can just peel up the bottom left and right corners until you can access the screws.
    • Use a spudger or your fingernail to peel up a corner of the sticker until you can grip it with your fingers.
    • Peel up the sticker with your fingers and remove it.
    Demander à FixBot
  4. Logitech G915 Wireless (Clicky) Battery Replacement, Remove the battery cover screws: étape 4, image 1 de 2 Logitech G915 Wireless (Clicky) Battery Replacement, Remove the battery cover screws: étape 4, image 2 de 2
    • Use a Phillips screwdriver to remove the two 4 mm‑long screws securing the battery cover.
    Demander à FixBot
  5. Logitech G915 Wireless (Clicky) Battery Replacement, Remove the USB receiver: étape 5, image 1 de 3 Logitech G915 Wireless (Clicky) Battery Replacement, Remove the USB receiver: étape 5, image 2 de 3 Logitech G915 Wireless (Clicky) Battery Replacement, Remove the USB receiver: étape 5, image 3 de 3
    • If you have a USB receiver stored in the battery cover compartment, use your finger to slide it out and remove it.
    Demander à FixBot
  6. Logitech G915 Wireless (Clicky) Battery Replacement, Reposition the battery cover: étape 6, image 1 de 3 Logitech G915 Wireless (Clicky) Battery Replacement, Reposition the battery cover: étape 6, image 2 de 3 Logitech G915 Wireless (Clicky) Battery Replacement, Reposition the battery cover: étape 6, image 3 de 3
    • Plastic clips secure the edges of the battery cover.
    • Insert your finger into the USB receiver compartment on the battery cover.
    • Pull up the bottom edge of the cover to release the clips.
    • Don't try to fully remove the cover yet, as it's still connected by the battery cable.
    • Gently pull the cover to the right so you can access the battery connector on the left side of the recess.
    Demander à FixBot
  7. Logitech G915 Wireless (Clicky) Battery Replacement, Disconnect the battery: étape 7, image 1 de 2 Logitech G915 Wireless (Clicky) Battery Replacement, Disconnect the battery: étape 7, image 2 de 2
    • Use a pair of angled tweezers to firmly grip the battery connector.
    • Hold the tweezers with your fingers as close to the connector as possible to get a firm grip.
    • Slide the connector straight out of its socket.
    • If you're having trouble, gently rock the connector side-to-side to help loosen it.
    Demander à FixBot
  8. Logitech G915 Wireless (Clicky) Battery Replacement, Remove the battery cover: étape 8, image 1 de 1
    • Remove the battery cover.
    • Congratulations on completing disassembly! The remaining steps will show you how to install your replacement battery and reassemble your device.
    Demander à FixBot
  9. Logitech G915 Wireless (Clicky) Battery Replacement, Install the new battery: étape 9, image 1 de 3 Logitech G915 Wireless (Clicky) Battery Replacement, Install the new battery: étape 9, image 2 de 3 Logitech G915 Wireless (Clicky) Battery Replacement, Install the new battery: étape 9, image 3 de 3
    • If your replacement battery comes attached to a new battery cover, skip the next three steps. Otherwise, follow the next three steps to remove the old battery from the cover and install your new one.
    • Light adhesive secures the battery to its cover.
    • Gently slide the flat end of a spudger under one of the short edges of the battery and lift to separate the adhesive.
    • Be very careful not to puncture the battery, as it can leak dangerous chemicals or catch fire.
    • Remove the battery from its cover.
    Demander à FixBot
  10. Logitech G915 Wireless (Clicky) Battery Replacement: étape 10, image 1 de 3 Logitech G915 Wireless (Clicky) Battery Replacement: étape 10, image 2 de 3 Logitech G915 Wireless (Clicky) Battery Replacement: étape 10, image 3 de 3
    Outil utilisé dans cette étape :
    Tesa 61395 Tape
    $8.95
    • Cut a piece of double-sided tape so it fits on the line of squares on the inside of the battery cover.
    • Press the tape firmly into place on the squares and remove the liner.
    Demander à FixBot
  11. Logitech G915 Wireless (Clicky) Battery Replacement: étape 11, image 1 de 1
    • Lay your new battery into its recess in the keyboard so the cable is on the left edge, near the battery connector.
    Demander à FixBot
  12. Logitech G915 Wireless (Clicky) Battery Replacement, Reconnect the battery: étape 12, image 1 de 2 Logitech G915 Wireless (Clicky) Battery Replacement, Reconnect the battery: étape 12, image 2 de 2
    • Insert the new battery's connector into its socket so the side with exposed pins is on the bottom.
    • Use a spudger to push the battery connector fully into its socket.
    Demander à FixBot
  13. Logitech G915 Wireless (Clicky) Battery Replacement, Install the battery cover: étape 13, image 1 de 1
    • Set the battery cover into place and firmly press down around its edges to engage all the clips.
    • You should feel and hear "clicks" as the clips engage.
    Demander à FixBot
  14. Logitech G915 Wireless (Clicky) Battery Replacement, Install the battery cover screws: étape 14, image 1 de 2 Logitech G915 Wireless (Clicky) Battery Replacement, Install the battery cover screws: étape 14, image 2 de 2
    • Use a Phillips screwdriver to install the two 4 mm‑long screws securing the battery cover.
    Demander à FixBot
  15. Logitech G915 Wireless (Clicky) Battery Replacement, Apply the battery cover sticker: étape 15, image 1 de 1
    • Use your fingers to apply the sticker to the battery cover.
    • To help the sticker adhere better, you can apply some heat with an iOpener or hair dryer.
    Demander à FixBot
Spencer Day
Membre depuis le 09/14/22
191 315 Réputation
1 204 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
122 membres
25 947 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 59
Total : 2,039
