Aller au contenu principal
Pour réparer ensemble - Je crée un compte
MacBook Air 13" Late 2010 Trackpad Replacement
Ce dont vous avez besoin
  1. MacBook Air 13" Late 2010 Trackpad Replacement, Lower Case: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, power off the device, close the lid and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 9 mm 5-point Pentalobe screws
    • Eight 2.6 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
    Demander à FixBot
    Ajouter un commentaire
  2. MacBook Air 13" Late 2010 Trackpad Replacement: étape 2, image 1 de 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    Demander à FixBot
  3. MacBook Air 13" Late 2010 Trackpad Replacement, Battery: étape 3, image 1 de 1
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Do not lift upward on the connector as you disconnect it.
    Demander à FixBot
  4. MacBook Air 13" Late 2010 Trackpad Replacement: étape 4, image 1 de 1
    • Remove the following five screws securing the battery to the upper case:
    • Three 6.3 mm T5 Torx screws
    • Two 2.4 mm T5 Torx screws
    Demander à FixBot
  5. MacBook Air 13" Late 2010 Trackpad Replacement: étape 5, image 1 de 1
    • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
    • The replacement battery may arrive with plastic liners and films. The plastic film is easily removable and should be removed before installation. The liner is thicker and acts as a layer of defense against punctures. Do not remove the liner from the battery.
    Demander à FixBot
  6. MacBook Air 13" Late 2010 Trackpad Replacement, Trackpad: étape 6, image 1 de 2 MacBook Air 13" Late 2010 Trackpad Replacement, Trackpad: étape 6, image 2 de 2
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap (on the side opposite the cable), not the socket itself.
    • Pull the trackpad ribbon cable straight out of its socket toward the rear edge of the Air.
    Demander à FixBot
  7. MacBook Air 13" Late 2010 Trackpad Replacement: étape 7, image 1 de 2 MacBook Air 13" Late 2010 Trackpad Replacement: étape 7, image 2 de 2
    • While carefully lifting the keyboard ribbon cable with one hand, use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Pull the keyboard ribbon cable straight out of its socket toward the front edge of the Air.
    Demander à FixBot
  8. MacBook Air 13" Late 2010 Trackpad Replacement: étape 8, image 1 de 1
    • Remove the following twelve screws:
    • Six 1.6 mm Phillips screws securing the trackpad to the upper case.
    • Six 1.6 mm Phillips screws securing the trackpad brackets to the trackpad.
    • A Phillips #000 should be sufficient, but a JIS #000 may also work as well.
    Demander à FixBot
  9. MacBook Air 13" Late 2010 Trackpad Replacement: étape 9, image 1 de 1
    • Remove the right and left trackpad brackets from the upper case.
    Demander à FixBot
  10. MacBook Air 13" Late 2010 Trackpad Replacement: étape 10, image 1 de 1
    • Remove the 1.4 mm T5 Torx set screw from its tapped hole near the front edge of the upper case.
    • During reassembly, do not over-tighten the set screw, as the button will cease to click at a certain point. Adjust the set screw until the movable side of the trackpad has minimal play.
    Demander à FixBot
  11. MacBook Air 13" Late 2010 Trackpad Replacement: étape 11, image 1 de 2 MacBook Air 13" Late 2010 Trackpad Replacement: étape 11, image 2 de 2
    • Use the flat edge of a spudger to carefully lift the edge of the trackpad closest to the keyboard from its recess in the upper case by lifting it away from the brackets attached to the upper case.
    • Remove the trackpad from the upper case.
    Demander à FixBot
19 autres ont terminé cette réparation.
3 commentaires de tutoriel
The screws are not Philips 00. They are smaller than Philips 000. I am looking for a screwdriver in that size.
I have the iFixit toolkit, and the PH000 tip simply did not fit into the head. The J000 tip could remove a couple screws, but started to strip the head of two others before I stopped. The tip almost stripped the two I removed on reinsertion.
The replacement trackpad comes with a set of these screws.
mikedesimone - Réponse Partager
No pictures : impossible to use
Pierre GENNEVOIS - Réponse Partager
Hey Pierre! There was an Amazon service outage that affected the images on this page. Take another look, you should be able to follow this guide now! =)
Sam Goldheart - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 15
30 derniers jours : 90
Total : 20,564
