Introduction
Use this guide to replace the right speaker in your MacBook Air 2022 (M2).
The right speaker is on the same side as the power button and headphone jack.
Ce dont vous avez besoin
Power off your MacBook Air and unplug all cables.
Close the display and flip the laptop upside down. Keep the lid closed until you've physically disconnected the battery.
Outil utilisé dans cette étape :FixMat$36.95
Use a P5 Pentalobe driver to remove the four 6.4 mm screws securing the lower case:
Two screws with a short threaded portion near the hinges
Two screws with a long threaded portion near the front of the MacBook
Apply a suction handle to the center of the lower case's front edge.
Pull up on the suction handle with strong, steady force to create a small gap between the lower case and the frame.
Insert an opening pick into the gap.
Slide the pick to the bottom right corner to release the first clip.
Slide the pick around the corner and up the right edge to release the next two clips.
Keep the lower case flat and firmly pull it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
Remove the lower case.
Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
Once the lower case is flush with the frame, press down firmly along the perimeter to engage the four snapping clips.
Use a T3 Torx driver to remove the two 1.5 mm screws securing the battery connector cover.
Use an opening pick to pry up and disconnect the battery connector.
Peel up and remove the foam pad from the lower display cable cover to reveal a hidden screw.
Use a T3 Torx driver to remove the seven 1.5 mm screws securing the three metal covers.
Use the pointed end of a spudger to pry up and disconnect the right speaker press connector.
Use a T3 Torx driver to remove the 2.6 mm screw securing the left hinge cover.
Grip the left hinge cover with blunt nose tweezers.
Pull the cover toward the bottom of the laptop and upward to free it from its recess.
Pull up and remove the hinge cover.
Use a T5 Torx driver to remove the three screws securing the right speaker:
Two 5.6 mm screws
One 3.5 mm screw
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting or check out our Answers community for help.
2 autres ont terminé cette réparation.
