Introduction
Avec ce tutoriel, remplacez un pavé tactile cassé.
Retirez les 10 vis suivantes par lesquelles est fixé le boîtier inférieur du MacBook Pro 13" Unibody :
  • Retirez les 10 vis suivantes par lesquelles est fixé le boîtier inférieur du MacBook Pro 13" Unibody :
    • Sept vis Phillips 3 mm.
    • Trois vis Phillips 13,5 mm.
It looks like you need a Phillips #000 screwdriver for the 10 bottom screws. I tried the #00 and it's too big. Good thing I bought a 23 piece precision screwdriver set or else I would have been screwed.
scott523 - Réponse
The 10 screws that hold tha bottom case take a #00 Phillips driver, if yours doesnt fit it's probably because it's cheaply made & not precise enough. The only thing that I needed a #000 driver for was the keyboard screws. They're so small they look like specks of dirt or sand. I stripped out 4 of them & now will need to grind the heads off with a Dremel/rotary tool. The other thing that sucks is iFixit doesn't have a tutorial for keyboard replacement!
iphonetechtips -
A true Phillips head screw's slots are rounded at their inner corners, to allow the screwdriver to "cam out" (pop out) of the screw head before you apply too much torque and strip the threads in the part that you're torqueing the screw into. However, the screws used in the Macbook don't have those rounded inner corners, so they're not Phillips. Instead, they may be a Japanese standard known as JIS B 1012, or a Frearson (also known as a Reed & Prince), but that's a less common design. Maybe technically these non-Phillips screws should be used with a screwdriver that was specifically designed for them, but they can be properly removed and reinstalled using a truly precision-made Phillips #00 (some people find a #000 sometimes works even better) whose tip comes to a sharp point--not the lousy fake "precision" screwdrivers that are sold in too many places. See my next comment for more.
johnsawyercjs -
Many screwdriver manufacturers get away with marketing fake "precision" screwdrivers because, in the words of the Wikipedia article at https://en.wikipedia.org/wiki/List_of_sc...: "Most heads come in a range of sizes, typically distinguished by a number, such as "Phillips #00" or "Torx T5." These sizes do not necessarily describe a particular dimension of the drive shape, but are often arbitrary designations in the same sense as a "Size 8" dress."
In other words, the quality of many "precision" screwdrivers is poor. In my experience, one of the biggest problems with many fake "precision" Phillips screwdrivers is that the four blades at the tip are often too wide, and their width may even vary on the same screwdriver (they're not supposed to). So just because a screwdriver is marketed as a "precision screwdriver", it may not be, and many that are labeled as #00, or even #000, will not work for a Macbook's screws. See my next comment for still more.
johnsawyercjs -
One of the best manufacturers of precision screwdrivers is Wiha (http://www.wihatools.com/tech-tools/prec... cost more, but they're worth it. Or buy screwdrivers from iFixit, who seem to be selling JIS screwdrivers.
Another article with some good info on screw and screwdriver types:
http://www.instructables.com/id/When-a-P...
Also keep in mind that some screws are tougher to remove and reinstall because they have a thread-locking compound on them, which is usually blue.
johnsawyercjs -
Phillips #00 is the correct screwdriver for the lower case. Maybe the one you have is worn or badly made.
David Fear -
Perfect man!Many thanks!:)
wertaerte - Réponse
Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
twisk - Réponse
thanks twisk, I wish i would have read your tip before I finished putting the bottom of my laptop back together. I managed to get all screws in somehow, but one was in fact too-tight.
BTW, big big thanks to the Author: Andrew Bookholt. Just used this guide and my trackpad now works again.
xitxit2 -
i too need a #000 for the bottom of the case -- i got the recommended screwdriver (#00) and unfortunately it's too big
plins718 - Réponse
Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
mastover - Réponse
I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
adlerpe -
That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
joyitsjennie -
Great idea and one I use often
Thomas Overstreet -
Excellent idea! Thanks for sharing it here.
Laura Sharkey -
The colours you used for these circles are indistinguishable for colour-blind people. Please consider using something like the palette suggested by visibone: http://www.visibone.com/colorblind/
Eric Sorenson - Réponse
Squares, Circles, Triangles (you get the idea) would work as well to distinguish the different screws.
danzeitlin -
I'd use a Phillips #000 screwdriver also. The #00 can work, but if the screws are in really tight, it doesn't get far enough down into the screws to get purchase, so it will start to strip (and I agree that the screws are pretty soft). On mine, the screws for the fan were really tight, started to strip with #00, needed a #000 and quite a bit of pressure to get them to move.
jonathanmorgan - Réponse
I thought it took a 000 as well. However, I tried both and realized the 00 works best.
john - Réponse
Hi i was wondering if you can add 16gb to this model? or is 8 the maximum?
Igor - Réponse
The Mid 2010 MacBook Pro 13" does support 16 GB RAM, but it is very picky about the type of RAM. OWC sells a 16 GB kit (2x 8 GB). I think it's got to be 1066 (aka 1067) MHz RAM. A lot of 8 GB modules on the market now are faster than 1066 MHz, and reports I've read say people start getting kernel panics if they use the wrong RAM.
Some info here:
http://www.everymac.com/systems/apple/ma...
"1066 MHz PC3-8500 DDR3 SDRAM"
"*Originally, both the official and actual maximum RAM was 8 GB. However, as confirmed by site sponsor OWC, if running OS X 10.7.5 or higher, updated with the latest EFI, and equipped with proper specification memory modules, this model can support up to 16 GB of RAM."
Our Mid 2010 already had "the latest EFI" (i.e. Boot ROM version in System Profiler), so the reference to updating it may not be relevant.
Winston -
I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
valentinedhdh - Réponse
I had the same problem. The #00 screwdriver worked for some of the screws but some others were too tight and I had to use a #000. Maybe it was because the cover had slightly bent because the battery inside had basically doubled its width, but I still found that the #000 was a much better fit for these screws. Even the ones that came out with the #00 came out much easier with the #000. I would suggest updating this guide to suggest using a #000.
tarriojuan - Réponse
Had no idea they were so expensive.
Franklin - Réponse
Phillips #00 is the right tool for all the steps (Except the 4 HD T6 screws). Maybe there is dirt in the notch.
Luis Soto - Réponse
There is any chance to use the Toshiba MQ01ABD 1 TB 2.5" Internal Hard Drive MQ01ABD100 , it has7200 rpm , shuold it work?
Luis - Réponse
If you are running OS X 10.11.2 or newer, battery provided by iFixIt will not work. I've already tried 2 batteries from iFixIt and neither worked. iFixIt needs to come clean on this unfortunate situation. I've already put 8 hours into this futile effort when it should have taken me 45 minutes.
gkofga - Réponse
What was your solution? I'm using 10.11.3 OS X. I may need a battery replacement very soon too.
John Doe -
<i>The 10 screws that hold that bottom case take a #00 Phillips driver, if yours doesn't fit it's probably because it's cheaply made & not precise enough.</I>
I purchased the IFixIt 54 bit Driver Kit and their Phillips #00 are <b>NOT</b> the appropriate size for the bottom screws on this MacBook Pro. This manual needs to have the tools changed to Phillips #000 Screwdriver. Until then I shall not click the "Give the author +30 points" button. Apart from that, the rest of the manual is very good. It would also be an idea to make a comment about making sure the battery connector is in the correct position when plugging the battery back in. One poster commented that their battery will not charge anymore. My guess is a pin(s) was/were bent due to the connection not being in the vertical orientation when being pressed back together. :-)
THANK YOU for writing and generously supplying this guide for our use. It is much appreciated. +30 point coming when the Phillips #000 size is changed or added.
Joseph King - Réponse
It would be nice to remind fixers which length screws go back in which holes, in case they get mixed up...
Mike - Réponse
Soulevez légèrement le boîtier inférieur et poussez-le vers l'arrière de l'ordinateur afin de désengager les pattes de fixation.
  • Soulevez légèrement le boîtier inférieur et poussez-le vers l'arrière de l'ordinateur afin de désengager les pattes de fixation.
In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
Mike - Réponse
Retirez les deux vis tri-point suivantes qui fixent la batterie au boîtier supérieur :
  • Retirez les deux vis tri-point suivantes qui fixent la batterie au boîtier supérieur :
  • Une vis tri-point de 5.5 mm.
  • Une vis tri-point de 13.5 mm.
Where can I buy 5.5 mm tri-wing screw and 13.5 mm tri-wing screw ?
gansodesoya - Réponse
I have the same question? Where can you buy new screws. Apple put in these rediculous tri-screws.... The short one went in crooked and jammed. I couldn't get the long one back in at all, not sure why, but it's not catching a single thread.
My 2nd question is, what the alternative if you can't get the screws back in (e.g. some kind of tape). With only one screw only half way in and jammed, the battery doesn't seem to be moving around, so I think I'm ok, at least for now.
Mike Mullally -
similar issue here, I'd like to buy these bolts new. and it would be even better to buy new ones but with a philips head, not a triwing head. please let us know. thanks.
Manuel Torres -
Still no answers on this?
jasperr4 - Réponse
You can get the tri-wings from ifixit directly - Tri-point Y1 Screwdriver
or get the whole kit (like I did - it's excellent) - Classic Pro Tech Toolkit
Damian Haslam - Réponse
i have a triwing y1 and it doesn't work with my battery it seems to be too big, the triwings sold on ifixit are the same when it is written y1 ?
Grazia Fiore -
The Y1-Three wing screwdriver from iFixit is too big!
Maik Lischke -
Just dropping saw someone with same name. :)
mdtorresjr - Réponse
Mine does not have triwing screws.... They have 5 points but none of my torx stuff works? What is it? I have one of your sets of 20 or so pieces and nothing works.....
Chris Babcock - Réponse
pentalobe. its an apple specific driver to keep you out. The bottoms of the airs use this as well. You can fid one on eBay
ryan rochford -
sure enough mine has the 5 star torx as well.. this drove me crazy today.....i had to buy a set of 5 stars from amazon....i thought i was losing my mind trying to make the tri wing fit....i finally opened my wife's 2010 macbook pro to find tri wings....then i knew. steve jobs was messing with me from the grave....lol
MICHAEL FENNEL -
Used a knife and a rubber band to unscrew these.
dovydas54 - Réponse
Pentalobe driver for newer Mac laptops worked, not the tri tip.
joeltbean - Réponse
These screws do absolutely NOT have the TRI-WING® recess. I find, the LHSTIX 3ULR MicroStix size 3ULR-0 driver fits perfectly.
unsubstantiated - Réponse
You're right and there was some inconsistent terminology in the guide. It should be fixed now. The term "tri-wing" doesn't apply here but I believe generic "tri-point" Y0 or Y1 drivers correspond to the Microstix driver you mention.
Jeff Suovanen -
A minor improvement, but it would be nice to remind fixers which screw length goes on which side (longer screw on _ side?)
Mike - Réponse
À l'aide de l'extrémité plate d'un spudger, faites levier sur le connecteur de la batterie pour le débrancher de la prise sur la carte mère.
  • À l'aide de l'extrémité plate d'un spudger, faites levier sur le connecteur de la batterie pour le débrancher de la prise sur la carte mère.
Ajouter un commentaire
Sortez la batterie du boîtier supérieur.
  • Sortez la batterie du boîtier supérieur.
Did everything correctly, but now the battery doesn't charge. Do I have to do something in particular to make it work now that's installed? Thanks
Olivier - Réponse
I am answering a 2 year old post but this is for those who may have the same or similar issue in the future.
When I was putting the battery connector back on that it didn't sit flat against the board before I put pressure on the top of the connecter to press it back into its socket. I then took time to examine the battery connector socket and saw it consisted of long thin vertical pins. I deduced that if the battery connector was not aligned correctly to the pins on the motherboard then it may be very easy to bend one or more of the pins in a way that they wouldn't mate up with the opposing female part on the connector. That sure would cause a battery charging issue. If you feel too much resistance when pressing the connector back into the socket then stop and make sure it is all aligned correctly. I know, not easy with the size, the black connector and black socket. A spudger can be used on the battery side of the connector to raise it to a level position prior to applying pressure to the top of it.
Joseph King -
Everything was so easy but that is not the highlight of it all; the replacement parts are cheaper than buying it from a local store here in Taiwan or in The Philippines.
Olivier, to answer your question, please read the 1st comment in the Guide section at the top. :)
aspeegle - Réponse
I have the same problem as Oliver. Replaced the battery, it Works, but don't charge. I don't see any comment on this page that answer his question.
torbernhardsen -
I too encountered the same problem. After resetting the SMC (http://support.apple.com/en-us/HT201295), it resolved the problem.
2CentsNoneTheRicher - Réponse
Replaced the battery without trouble. But now I turn on the computer and get a white screen. Any idea what I am missing?
Claire Hoelmer - Réponse
I put the battery in ok, then placed it on charge and tried to start it. It didn't like this at all, letting out evenly spaced unfamiliar beeps. I felt sure i had done something terrible. I held down the start button and turned it off. Half an hour later I turned it back on, upon which it sprung back to life, much to my relief. The battery needed to be charged before starting it seems.
Guy Wishart - Réponse
Avec l'extrémité plate d'une spatule (spudger), faites levier sur le connecteur du pavé tactile pour le débrancher de sa prise sur la carte mère.
  • Avec l'extrémité plate d'une spatule (spudger), faites levier sur le connecteur du pavé tactile pour le débrancher de sa prise sur la carte mère.
Ouvrez votre MacBook Pro et posez-le sur une table comme sur la photo.
  • Ouvrez votre MacBook Pro et posez-le sur une table comme sur la photo.
Pendant que vous maintenez d'une main le bord du pavé tactile le plus proche possible de la carte mère, dévissez les quatre vis cruciformes de 1,2 mm entourées en rouge.
  • Pendant que vous maintenez d'une main le bord du pavé tactile le plus proche possible de la carte mère, dévissez les quatre vis cruciformes de 1,2 mm entourées en rouge.
I ordered some tools from iFixit for replacement of the trackpad but the Phillips #00 Screwdriver named above is still too big for the (tiny) screws of the trackpad. Shouldn't that be a Philips #000?
sleutelman - Réponse
I have a macbook pro 15 inch unibody from 2010-2011, do you think it would work to use that trackpad as an replacement for my 13 inch 2012-2013
Filip - Réponse
A word of caution if you are replacing your trackpad due to a bulging battery. This guide assumes that the original mounting tabs are not damaged and it does not look like the iFixit trackpad replacement kit comes with new tabs. My MBP had a bulging battery, which pushed up on the bottom of my trackpad, deforming one of these tabs. Now that I have removed the battery, the trackpad still works, but it is not flush with the case and the physical clicks are not as responsive as I would like. Does iFixit sell just the replacement tabs?
Matt Marchese - Réponse
Same here luckily the trackpad still works but the taps have deformed. Anyone find a place to pick up just those tabs? Edit: found them MacBook Pro Unibody (Mid 2009 through Mid 2012) Trackpad Mounting Screws
iAndrewC -
Be careful with this step. The very tiny screws are very hard to remove with a #00 screwdriver. I tried with mine and I mashed the srews heads, it was then very very hard to remove it. Better to use a #000 screwdriver. If the heads are mashed like me, I suggest you use a 0.1 flat screwdriver, it worked well in my case.
Jonathan - Réponse
I couldn't even begin to use the #000 as the edges were not deep or narrow enough for the condition of the screws from factory install. The .1 flat screwdriver worked like a charm though and didn't mess up the screws further at all. I was getting nervous that I'd need to get another screwdriver beyond what's in the iFixit toolkit, but this worked as a better solution.
Thom Merrick -
I used the J000 head from the iFixit kit and it fit pretty snug, and the screws came out very cleanly
andrew - Réponse
Si nécessaire, délogez soigneusement le bord du pavé tactile le plus proche du clavier de son emplacement dans le boîtier supérieur en l'éloignant des fixations attachées au boîtier supérieur. Poussez soigneusement le connecteur et la nappe du pavé tactile à travers la fente dans le boîtier supérieur. Il est peut-être nécessaire d'utiliser une spatule pour aider le connecteur du pavé tactile à passer à côté du bord de la carte mère.
  • Si nécessaire, délogez soigneusement le bord du pavé tactile le plus proche du clavier de son emplacement dans le boîtier supérieur en l'éloignant des fixations attachées au boîtier supérieur.
  • Poussez soigneusement le connecteur et la nappe du pavé tactile à travers la fente dans le boîtier supérieur.
  • Il est peut-être nécessaire d'utiliser une spatule pour aider le connecteur du pavé tactile à passer à côté du bord de la carte mère.
  • Une fois que la nappe est complètement enlevée de sa fente dans le boîtier supérieur, éloignez le pavé tactile du bord extérieur du boîtier supérieur et ôtez-le de l'ordinateur.
Lors de l'installation de votre nouveau pavé tactile, il peut être difficile de faire passer la nappe à travers le boîtier supérieur puis à côté de la carte mère. La pointe d'une spatule peut vous aider à guider le connecteur à côté de la carte mère pendant que vous poussez la nappe à travers sa fente dans le boîtier supérieur de l'autre main.
  • Lors de l'installation de votre nouveau pavé tactile, il peut être difficile de faire passer la nappe à travers le boîtier supérieur puis à côté de la carte mère. La pointe d'une spatule peut vous aider à guider le connecteur à côté de la carte mère pendant que vous poussez la nappe à travers sa fente dans le boîtier supérieur de l'autre main.
This article seems to be about REPLACING a trackpad. Why does the summary claim that no parts are needed?
Sam Pittman - Réponse
If your replacement trackpad comes with the cable separated and loose, the connection to the trackpad needs to have a tab pressed down which keeps the connection snug. It won't work without it. It's a tab on the trackpad part of the connection. Tab might be the wrong word; the connection has to be in all the way, then clamp it closed with the tab... oops! LOL
Mark - Réponse
Ensuite, remettez les quatre vis cruciformes de 1,2 mm le long du bord intérieur du pavé tactile. Serrez complètement les vis, puis desserrez-les d'un quart de tour.
  • Ensuite, remettez les quatre vis cruciformes de 1,2 mm le long du bord intérieur du pavé tactile.
  • Serrez complètement les vis, puis desserrez-les d'un quart de tour.
  • Vérifiez l'alignement du pavé tactile du côté clavier du boîtier supérieur. Une fois que vous avez centré le pavé tactile dans le boîtier supérieur, serrez complètement les quatre vis cruciformes.
trackpad still doesn't click. I've tried two separate parts.. but what makes it pop back up after depressing the pad? It just lays there. I've taken it apart four times to adjust the tork screw... nothing. HELP!
Gail - Réponse
My trackpad was driving me up the wall, bouncing all over the place. Ifixit Trackpad comes with extra screws, hinge and adjuster. You won't believe how tiny these screws are! If one falls in the carpet-it's GONE! Bless you Ifixit! To center when re-installing adjust by sliding a thin piece of paper (scotch tape?), under bottom of trackpad, let Trackpad rest on it's own weight and then tighten one top and bottom screw a little bit, and eyeball it, just the tiniest crack of daylight on each side. I strongly suggest the highest quality magnetic screwdriver you can find. The little torx screw disc is an adjuster. If too tight, trackpad won't 'click.' On a Mac, click is not really essential as long as tap and slide are working right. Needs a small amount of clearance. When properly installed you can 'feel' the click if it's right. Probably won't need to mess with it at all. Now my trackpad works like it should, I am a happy camper!
ovenwally - Réponse
I replaced the trackpad with a new one: the arrow moves but was not possible to click. I putted back the old trackpad and it works with. The solution: the eleventh picture shown a gray Torx type screw to the left of the connector where there is the recess in the back of the mouse. This screw is used to increase or decrease the depth of clicks. in my case it was too screwed and it was as if I held continually pressed the truckpad: therefore, it was enough to loosen it. At this point I ask myself since in the old truckpad I had problems with the physical click, I probably would have been enough to adjust the screw.
caronte88 - Réponse
Vielen Dank, dies hat mir sehr beholfen :-)
Frederik Häger -
ifitit is once again amazing. My trackpad just stopped working on my four year old machine. Bought a new trackpad from iFitit, followed the guide and now I have a functional laptop again. One thing to note. 1.2mm is small very, very small. The screws for the trackpad *will* get lost if they fall of the table. Make sure that doesn't happen.
Jerry - Réponse
I was having trackpad issue on my 2010 machine, did the replacement from ifixit which arrived broken (bummer) but they replaced it no problems. It worked great for just under a year but now I'm having the same issues again of poor finger tacking, jumping, and lack of sensitivity. I've tried cleaning the whole unit, rebooting in safe mode, refreshing code, and anything else the web has provided. I'm starting to wonder if it's something else on my machine or if the trackpads just don't hold up well enough. Overall I'm super frustrated to have a newer pad crap out this early.
eastern117 - Réponse
I don't have a magnetic head driver so I had a terrible time trying to get the screws in. I found getting the screw on the table Phillips side up, I pushed my finger tip into the head til it stuck and placed the screw into the thread that way. The screw stayed in long enough for me to tighten with the driver ! Oh, what a relief! I only lost one screw; thank god for replacement screws! Order your trackpad with screws! They fall and get lost easy! Now I'm happy! :)
Mark - Réponse
Next time rub the tip of the screwdriver against a magnet about 10-20 times in the SAME direction (A fridge magnet works)
Karan Kakkar -
For some reason the black material under the tabs were enough to stop the track pad from being able to click. I removed that material and now have a track pad that clicks.
blrmisc - Réponse
Pour remonter votre ordinateur, suivez les instructions dans l'ordre inverse.
149 autre(s) ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
11 commentaires
I replaced the trackpad and the new one had a strange behave: the arrow moves, the multi-touch works, but was not possible to click and when the arrow passes on the dock it doesn't react at all, then I plugged in an external mouse and the behave was the same (in few words it was impossible to use the computer).
Now I putted back the old trackpad and I work with the external mouse.
Did someone experienced something similar?
Did you solve in some way?
Thank you in advance.
Fortunato - Réponse
Hello,
I also had a similar problem. I was told to try to reset the SMC in this way:
1. Attach the MagSafe power cord
2. Power off the MacBook Pro
3. Press the L-Shift/Control/Option and Power button at the same time and hold.
4. Release them all at the same time
5. Then power on the MacBook Pro
but didn't work for me. Any other suggestion?
donato spoltore - Réponse
Anyone have trouble with the trackpad acting wonky after installation? Clicking well, but the right 1/3 side does not track properly. Cursor will start to go all over the place or stop. Also installed an Anker replacement battery as well, took off the foot pads as recommended. Just trying to figure out if it's software or hardware. (i.e. did I get a faulty replacement trackpad.).
Thanks!
skiwildcat7 - Réponse
Thanks for this very precise step-by-step guide! Good old MBP works fine again.
Cost: Track pad from China € 26, ifixit screwdriver set € 25 - compared to the Apple shop's cost estimate a real big deal!
Wolfgang Ehle - Réponse
Thank you IfixIt . It was a breeze to fix my trackpad. Took me all of 15 min. No adjustments needed in my case. I did go with the 000 driver instead of the 00 because of comment left here and it worked flawlessly . My next project is my screen on a iPad 4th gen. Thanx again and wish me luck .
cuban4lf - Réponse
I've replaced the trackpad and it's working fine, except that the fan is always at maximum speed and never stop or slow down as soon as the macbook starts, so it's kindy noisy. I tried to reinstall the old trackpad (which doesn't click anymore), and fan went back to normal.
So, even if i don't know how the two are related, the new trackpad makes the fan go crazy. I've tried all kind of reset, smc etc... but no luck. Any idea?
Arnaud - Réponse
1st off shipping... WAS SUPER QUICK via FEDEX!!!!
Wow that was super easy!
So glad I purchased the "Essential Electronics Tool kit" Made the repair that much easier!(Right tools for the right job)
I was a little worried as the trackpad it self did not click but after aligning it and then tightening the 4 screws down it was fine!
Also purchased a new Battery and replaced that the same time, such a breeze!
Thanks IFIXIT completely satisfied and will recommend to all my friends!
getednam - Réponse
I replaced the trackpad on my MacBook Pro 13" Mid 2009 model with iFixit's used trackpad (with screws) and it is working perfectly. The guide was easy to follow and all the recommended tools above worked well. The only trouble I had was unscrewing the screws from the trackpad. I had to push from the other side of the trackpad to get the screwdriver to turn them. I recommend getting new screws with the new trackpad as I just about stripped the old ones because of this problem. Thank you iFixit for saving me a trip to the Apple store and paying for an expensive repair.
megaflip - Réponse
Trackpad Replacement Guide was perfect. So were other guides pointing to possible battery culpability in "no click registration" problem in trackpad. After troubleshooting the battery (not the culprit in my machine), I bought the replacement trackpad and the $10 set of screws & misc items for trackpad fix, followed the steps (holding breath), and bingo -- clicker works again. Caution: your 00 philips needs a magnetic tip to work the microscopic trackpad mounting screws. The 000 tip worked for me on the MacBook case but 00 tip was needed to muscle the tiny trackpad screws. My new Trackpad must have shipped with a mini-ziplock bag of replacement screws, though I didn't notice until nearly done with the replacement. Still totally glad I spent the $10 extra to get a "for sure" set of new screws in case of head strip (unlikely you will strip threads but possible to score the philips notches because they are seated really tight). I had no problems with trackpad functionality after the install. Totally perfect.
johnpiperjr - Réponse
Repair went smoothly and trackpad works great! I'm a cheap-o and bought the used trackpad without extra screws (one beer down and I was still able to manage not losing the original screws, phew!). As you may have guessed, I spilled red wine all over my computer and luckily there was no internal damage except for the trackpad. The mouse moved and clicked but did not register the clicks. I was worried that it may have been a deeper issue than only the trackpad, but just my luck that things worked out in my favor. Thank you to the contributor for this easy repair guide!
Rachel Freid - Réponse
What's wrong with the idea of removing the cable from the trackpad itself and re-using it with a new cable-less replacement trackpad? Wouldn't that be MUCH easier?
tracy - Réponse
Voir les statistiques:
Dernières 24 heures : 10
7 derniers jours : 93
30 derniers jours : 479
Total : 98,034
