Introduction
Use this guide to replace one or both speakers in your MacBook Pro 14" 2021.
For your safety, discharge the battery below 25% before disassembling your MacBook. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
Ce dont vous avez besoin
Outil utilisé dans cette étape :FixMat$36.95
Use a P5 Pentalobe driver to remove eight screws securing the lower case:
Four 9.3 mm screws
Four 5 mm screws
Press a suction handle into place near the front edge of the lower case, between the screw holes.
Pull up on the suction handle to create a small gap under the lower case.
Insert an opening pick into the gap you just created.
Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
Repeat the previous step on the other side, using an opening pick to to release the second clip.
Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
Remove the lower case.
Lay it down and align the sliding clips with the back edge of the MacBook. Press down on the lower case and slide it toward the back edge to engage the clips.
Once the back corners of the lower case are secured and flush with the frame, press down along the middle of the lower case to engage the four remaining clips.
Peel back any tape covering the battery board data cable connector on the logic board.
Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
Use a T3 Torx driver to remove the two 2.1 mm‑long 3IP Torx Plus screws securing the trackpad cable bracket to the logic board.
Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector secured to the logic board.
Peel the trackpad cable away from the device, making sure to separate the adhesive.
Peel back any tape covering the battery board data cable connector under the large pancake screw.
Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
Remove the battery board data cable.
Use a T5 Torx driver to remove the 3.8 mm 5IP Torx Plus wide-head screw securing the battery power connector.
Use the flat end of your spudger to lift the battery connector away from the battery board, disconnecting the battery.
Peel back the tape covering the right speaker ZIF connector.
Follow the procedure in the previous three steps to disconnect the left speaker.
Apply a few drops of highly-concentrated isopropyl alcohol (>90%) in the gap between the speaker and the edge of the frame.
Wait for 1–2 minutes to allow time for the isopropyl alcohol to weaken the adhesive.
Insert the tip of an opening pick in the gap between the speaker and the edge of the frame.
Slide the opening pick along the edge of the speaker to slice the adhesive beneath it.
Outil utilisé dans cette étape :Tesa 61395 Tape$5.99
Use your fingers to remove the speaker, making sure to peel off any remaining adhesive.
Repeat the loosening and separating process for the other speaker.
Clean up any remaining adhesive from the frame before installing new adhesives.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 14" 2021 Answers community for help.
4 autres ont terminé cette réparation.
2 commentaires
The description up top alludes to having to remove the logic board + fans to replace the speakers, but that doesn't seem to be the case in the step by step. Can anyone who's completed this speaker replacement clear that up?
Hi thardee, thanks for pointing that out. You're right, the logic board and fans don't need to be removed to replace the speakers. I've removed that section from the description.
