Aller au contenu principal
Motorola Edge (2022) Camera Bezel Replacement
Ce dont vous avez besoin
  1. Motorola Edge (2022) Camera Bezel Replacement, Heat the right edge: étape 1, image 1 de 1
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Motorola Edge (2022) Camera Bezel Replacement, Insert an opening pick: étape 2, image 1 de 2 Motorola Edge (2022) Camera Bezel Replacement, Insert an opening pick: étape 2, image 2 de 2
    • Insert an opening pick between the camera bezel and the back cover.
  3. Motorola Edge (2022) Camera Bezel Replacement, Slice the camera bezel adhesive: étape 3, image 1 de 2 Motorola Edge (2022) Camera Bezel Replacement, Slice the camera bezel adhesive: étape 3, image 2 de 2
    • Slide the pick around the perimeter of the camera bezel to slice all the adhesive securing the bezel.
    • You may have to repeat this process multiple times to completely cut all of the adhesive.
  4. Motorola Edge (2022) Camera Bezel Replacement, Remove the camera bezel: étape 4, image 1 de 2 Motorola Edge (2022) Camera Bezel Replacement, Remove the camera bezel: étape 4, image 2 de 2
    • Lift the camera bezel away from the phone and remove it.
To reassemble your device, follow the instructions in reverse order.
Spencer Day
Membre depuis le 09/14/22
55 032 Réputation
407 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 336 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 10
Total : 335
