Aller au contenu principal
Pour réparer ensemble - Je crée un compte
OnePlus 9 Pro Screen Replacement
Ce dont vous avez besoin
  1. OnePlus 9 Pro Screen Replacement, Rear Glass: étape 1, image 1 de 1
    • For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
    • Unplug any chargers/peripheries and power off your phone.
    Demander à FixBot
    Ajouter un commentaire
  2. OnePlus 9 Pro Screen Replacement: étape 2, image 1 de 1
    Demander à FixBot
  3. OnePlus 9 Pro Screen Replacement: étape 3, image 1 de 2 OnePlus 9 Pro Screen Replacement: étape 3, image 2 de 2
    • Use a hair dryer to lightly heat the perimeter of the rear glass.
    • Additionally, heat the top-right corner, as there is adhesive further inside of phone in that one spot.
    • Do not hold the hair dryer in one spot on the phone for too long to prevent damage to internal parts of the phone.
    Demander à FixBot
  4. OnePlus 9 Pro Screen Replacement: étape 4, image 1 de 1
    • Apply a suction handle as close to the bottom edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the glass and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive.
    • Insert an opening pick into the gap.
    Demander à FixBot
  5. OnePlus 9 Pro Screen Replacement: étape 5, image 1 de 1
    • Slide the opening pick around the perimeter of the rear glass to slice the adhesive.
    • Insert additional opening picks as you slice the adhesive to prevent the adhesive from resealing.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your hair dryer to reheat it.
    Demander à FixBot
  6. OnePlus 9 Pro Screen Replacement: étape 6, image 1 de 2 OnePlus 9 Pro Screen Replacement: étape 6, image 2 de 2
    • Carefully lift the rear glass up and off of the phone.
    • During reassembly secure the rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
    Demander à FixBot
  7. OnePlus 9 Pro Screen Replacement, Bottom Loudspeaker: étape 7, image 1 de 2 OnePlus 9 Pro Screen Replacement, Bottom Loudspeaker: étape 7, image 2 de 2
    • Use one of the opening picks to remove the adhesive on the lower part of the wireless charging cable
    Demander à FixBot
  8. OnePlus 9 Pro Screen Replacement: étape 8, image 1 de 3 OnePlus 9 Pro Screen Replacement: étape 8, image 2 de 3 OnePlus 9 Pro Screen Replacement: étape 8, image 3 de 3
    • Unplug the press connector ribbon cable attached to the flash module by inserting a spudger under the bottom edge and prying straight up.
    • Use an opening pick to remove the flash module by the camera.
    • Use a Phillips #000 screwdriver to remove the eleven 4.9 mm-long screws holding the motherboard cover to the phone.
    • Use an opening pick to pry off the motherboard cover.
    Demander à FixBot
  9. OnePlus 9 Pro Screen Replacement: étape 9, image 1 de 1
    • Use a Phillips #000 screwdriver to remove five screws that secure the lower daughterboard cover.
    • Two of the screws have a white head and are 4.8 mm-long. They go in the bottom right corner of the daughter and mother board.
    • The other three screws are black and are also 4.8 mm-long.
    Demander à FixBot
  10. OnePlus 9 Pro Screen Replacement: étape 10, image 1 de 2 OnePlus 9 Pro Screen Replacement: étape 10, image 2 de 2
    • Disconnect the two interconnect cables by inserting a spudger under each lip and prying straight up.
    Demander à FixBot
  11. OnePlus 9 Pro Screen Replacement: étape 11, image 1 de 1
    • Remove the three screws from the loudspeaker using a Phillips #000 screwdriver.
    Demander à FixBot
  12. OnePlus 9 Pro Screen Replacement: étape 12, image 1 de 1
    • Use the spudger to pry up and remove the loudspeaker.
    Demander à FixBot
  13. OnePlus 9 Pro Screen Replacement, Battery: étape 13, image 1 de 3 OnePlus 9 Pro Screen Replacement, Battery: étape 13, image 2 de 3 OnePlus 9 Pro Screen Replacement, Battery: étape 13, image 3 de 3
    • Use an opening pick or tweezers to carefully peel back the adhesive on the bottom of the wireless charging module.
    Demander à FixBot
  14. OnePlus 9 Pro Screen Replacement: étape 14, image 1 de 3 OnePlus 9 Pro Screen Replacement: étape 14, image 2 de 3 OnePlus 9 Pro Screen Replacement: étape 14, image 3 de 3
    • Pry on the bottom of the flash module off using a pick and use tweezers to get under the module without ripping it.
    • Be careful unplugging the module as the cable is very delicate.
    Demander à FixBot
  15. OnePlus 9 Pro Screen Replacement: étape 15, image 1 de 1
    • Use a Phillips #000 screwdriver to remove the eleven 4.8 mm-long screws securing the motherboard cover.
    Demander à FixBot
  16. OnePlus 9 Pro Screen Replacement: étape 16, image 1 de 3 OnePlus 9 Pro Screen Replacement: étape 16, image 2 de 3 OnePlus 9 Pro Screen Replacement: étape 16, image 3 de 3
    • Pry around the phone with picks to remove the motherboard cover.
    Demander à FixBot
  17. OnePlus 9 Pro Screen Replacement: étape 17, image 1 de 1
    • Lift off the motherboard cover.
    Demander à FixBot
  18. OnePlus 9 Pro Screen Replacement: étape 18, image 1 de 2 OnePlus 9 Pro Screen Replacement: étape 18, image 2 de 2
    • Pry up and disconnect the press connector ribbon cable in the top right with a spudger.
    • Make sure not to damage them in the process.
    Demander à FixBot
  19. OnePlus 9 Pro Screen Replacement: étape 19, image 1 de 3 OnePlus 9 Pro Screen Replacement: étape 19, image 2 de 3 OnePlus 9 Pro Screen Replacement: étape 19, image 3 de 3
    • Use a spudger to disconnect the two interconnect cables from the motherboard by prying the connector straight up from its socket.
    Demander à FixBot
  20. OnePlus 9 Pro Screen Replacement: étape 20, image 1 de 2 OnePlus 9 Pro Screen Replacement: étape 20, image 2 de 2
    • Take care not to bend or puncture battery during the removal procedure—a bent battery may leak dangerous chemicals or cause a fire.
    • Remove the battery from the phone by slowly pulling up on the red tabs.
    • If you're having trouble lifting the battery out of its recess, apply a heated iOpener to the screen side for two minutes to loosen the battery adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    Demander à FixBot
  21. OnePlus 9 Pro Screen Replacement, Screen: étape 21, image 1 de 2 OnePlus 9 Pro Screen Replacement, Screen: étape 21, image 2 de 2
    • Use the spudger to unplug the ribbon cable that connects the screen to the rest of the phone.
    Demander à FixBot
  22. OnePlus 9 Pro Screen Replacement: étape 22, image 1 de 1
    • Place the suction cup on the glass towards the bottom of the screen.
    Demander à FixBot
  23. OnePlus 9 Pro Screen Replacement: étape 23, image 1 de 1
    • Heat the adhesive holding the screen onto the phone by using the heat gun on the edges of the screen.
    • Be sure to use caution when using the heat gun.
    Demander à FixBot
  24. OnePlus 9 Pro Screen Replacement: étape 24, image 1 de 3 OnePlus 9 Pro Screen Replacement: étape 24, image 2 de 3 OnePlus 9 Pro Screen Replacement: étape 24, image 3 de 3
    • Put the jimmy into the bottom edge of the screen.
    • Use an opening pick to slice the adhesive, and place opening picks around the perimeter as you slice to avoid the adhesive from resealing.
    • Reheat the screen as needed.
    Demander à FixBot
  25. OnePlus 9 Pro Screen Replacement: étape 25, image 1 de 2 OnePlus 9 Pro Screen Replacement: étape 25, image 2 de 2
    • Carefully pull up on the suction cup to pull the screen away from the phone.
    Demander à FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Averie
Membre depuis le 02/17/25
291 Réputation
2 tutoriels rédigés
Équipe
University of Memphis, Team 1-1, Sneed Spring 2025 Membre de l'équipe University of Memphis, Team 1-1, Sneed Spring 2025
UM-SNEED-S25S1G1
4 membres
12 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 53
30 derniers jours : 216
Total : 2,582
