Aller au contenu principal
Samsung Galaxy Note9 Rear Camera Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Note9 Rear Camera Replacement, Eject the SIM card tray: étape 1, image 1 de 2 Samsung Galaxy Note9 Rear Camera Replacement, Eject the SIM card tray: étape 1, image 2 de 2
    • Insert a SIM card eject tool straight into the hole in the SIM card tray.
    • Press to eject the SIM card tray.
  2. Samsung Galaxy Note9 Rear Camera Replacement, Remove the SIM card tray: étape 2, image 1 de 1
    • Remove the SIM card tray.
    • The SIM card will fall out of the tray easily.
  3. Samsung Galaxy Note9 Rear Camera Replacement, Apply a heated iOpener: étape 3, image 1 de 1
    • Power off your phone before beginning disassembly.
    • Use a hairdryer, a heatgun, or prepare an iOpener and apply it to the right edge of the back of the phone for about a minute to soften the adhesive underneath.
  4. Samsung Galaxy Note9 Rear Camera Replacement, Insert an opening pick: étape 4, image 1 de 3 Samsung Galaxy Note9 Rear Camera Replacement, Insert an opening pick: étape 4, image 2 de 3 Samsung Galaxy Note9 Rear Camera Replacement, Insert an opening pick: étape 4, image 3 de 3
    • Apply a suction handle to the back cover.
    • Lift with a suction handle to create a gap between the back cover and the frame of the phone.
    • Insert an opening pick into the gap.
    • If the glass is badly cracked, cover it in packing tape to create a surface for the suction cup to adhere to.
    • If the adhesive won't budge, apply more heat, not excessive force. Too much force could break the glass.
  5. Samsung Galaxy Note9 Rear Camera Replacement, Cut through the adhesive: étape 5, image 1 de 1
    • Note that there is more adhesive along the top edge and around the camera bezel than around the rest of the phone.
    • Cut carefully around the left edge near the fingerprint sensor or you risk damaging the ribbon cable inside.
    • If, at any point, the adhesive feels stubborn, apply more heat—not more force.
  6. Samsung Galaxy Note9 Rear Camera Replacement, Slide the opening pick: étape 6, image 1 de 3 Samsung Galaxy Note9 Rear Camera Replacement, Slide the opening pick: étape 6, image 2 de 3 Samsung Galaxy Note9 Rear Camera Replacement, Slide the opening pick: étape 6, image 3 de 3
    • Starting from the center, cut the adhesive up and down the right side with an opening pick.
    • Do not insert the pick more than halfway into the phone when cutting near the fingerprint sensor or cameras, or you risk damaging internal components.
  7. Samsung Galaxy Note9 Rear Camera Replacement: étape 7, image 1 de 3 Samsung Galaxy Note9 Rear Camera Replacement: étape 7, image 2 de 3 Samsung Galaxy Note9 Rear Camera Replacement: étape 7, image 3 de 3
    • Be careful near the corner, as the glass is very weak. Apply more heat at any time if the adhesive becomes stuck.
    • Leave an opening pick in the upper-right corner.
    • Use another opening pick to cut the adhesive around the bottom-right corner.
    • Leave that opening pick in the phone.
  8. Samsung Galaxy Note9 Rear Camera Replacement: étape 8, image 1 de 1
    • Use a heat gun or hair dryer or apply a heated iOpener to the left side of the rear panel for at three minutes to soften the adhesive underneath.
  9. Samsung Galaxy Note9 Rear Camera Replacement: étape 9, image 1 de 3 Samsung Galaxy Note9 Rear Camera Replacement: étape 9, image 2 de 3 Samsung Galaxy Note9 Rear Camera Replacement: étape 9, image 3 de 3
    • Be careful near the corners, as the glass is weakest there.
    • Insert an opening pick into the lower-left corner of the rear panel.
    • Using another opening pick, cut the adhesive along the left edge of the rear panel.
    • Don't insert an opening pick in more than halfway on the left edge near the fingerprint sensor or you may damage the ribbon cable inside.
    • It is fine if opening picks fall out as the back cover becomes separated.
  10. Samsung Galaxy Note9 Rear Camera Replacement: étape 10, image 1 de 3 Samsung Galaxy Note9 Rear Camera Replacement: étape 10, image 2 de 3 Samsung Galaxy Note9 Rear Camera Replacement: étape 10, image 3 de 3
    • Using the inserted opening pick, carefully cut the adhesive around the upper-left corner of the rear panel.
    • Finally, cut the last of the adhesive along the top of the phone.
    • Use an iOpener, hair dryer, or heat gun to apply more heat as needed where you are cutting the adhesive.
  11. Samsung Galaxy Note9 Rear Camera Replacement: étape 11, image 1 de 2 Samsung Galaxy Note9 Rear Camera Replacement: étape 11, image 2 de 2
    • Separate the right side of the rear cover first.
    • Tilt the cover up along the left edge to expose the fingerprint sensor ribbon cable.
    • Do not pull out the fingerprint sensor ribbon cable yet.
    • The fingerprint sensor cover might stay attached to the midframe.
  12. Samsung Galaxy Note9 Rear Camera Replacement, Disconnect the fingerprint sensor: étape 12, image 1 de 2 Samsung Galaxy Note9 Rear Camera Replacement, Disconnect the fingerprint sensor: étape 12, image 2 de 2
    • Use the tip of a spudger to pry the fingerprint sensor ribbon cable up and out of its socket.
  13. Samsung Galaxy Note9 Rear Camera Replacement: étape 13, image 1 de 1
    • Remove the back cover.
    • To re-install the back cover:
    • Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive. You don't have to clear out adhesive down to the plastic but larger pieces should be removed.
    • Turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • Carefully apply the new adhesive to the back cover, then line up one edge of the glass against the phone chassis and firmly press the glass into the phone.
  14. Attention : les étapes 14 à 17 sont issues d'un tutoriel marqué comme en cours.
    Samsung Galaxy Note9 Rear Camera Replacement, Remove the upper midframe: étape 14, image 1 de 2 Samsung Galaxy Note9 Rear Camera Replacement, Remove the upper midframe: étape 14, image 2 de 2
    • Use a Phillips screwdriver to remove the nine 4 mm screws securing the upper midframe.
  15. Samsung Galaxy Note9 Rear Camera Replacement: étape 15, image 1 de 2 Samsung Galaxy Note9 Rear Camera Replacement: étape 15, image 2 de 2
    • Insert the tip of a spudger into the upper-left corner of the upper midframe.
    • Pry the upper midframe out of the phone.
    • The upper midframe snaps into and out of place.
  16. Samsung Galaxy Note9 Rear Camera Replacement: étape 16, image 1 de 3 Samsung Galaxy Note9 Rear Camera Replacement: étape 16, image 2 de 3 Samsung Galaxy Note9 Rear Camera Replacement: étape 16, image 3 de 3
    • Peel the wireless charging coil off the battery starting with the left side.
    • The adhesive is weak but you can use an opening pick to cut it if necessary.
    • During reassembly start by snapping the midframe into place first before adhering the wireless charging coil.
  17. Samsung Galaxy Note9 Rear Camera Replacement, Disconnect the battery: étape 17, image 1 de 2 Samsung Galaxy Note9 Rear Camera Replacement, Disconnect the battery: étape 17, image 2 de 2
    • Use the tip of a spudger to disconnect the orange ribbon cable connecting the battery to the motherboard.
  18. Samsung Galaxy Note9 Rear Camera Replacement, Remove the midframe: étape 18, image 1 de 2 Samsung Galaxy Note9 Rear Camera Replacement, Remove the midframe: étape 18, image 2 de 2
    • Remove the nine 4 mm Phillips screws from the plastic cover next to the battery.
  19. Samsung Galaxy Note9 Rear Camera Replacement: étape 19, image 1 de 1
    • Remove the plastic cover next to the battery.
  20. Samsung Galaxy Note9 Rear Camera Replacement: étape 20, image 1 de 3 Samsung Galaxy Note9 Rear Camera Replacement: étape 20, image 2 de 3 Samsung Galaxy Note9 Rear Camera Replacement: étape 20, image 3 de 3
    • Insert the tip of a spudger into the top of the lower midframe.
    • Pry the lower midframe out from the phone.
    • The lower midframe snaps into and out of place.
    • Remove the lower midframe.
  21. Samsung Galaxy Note9 Rear Camera Replacement, Remove the front camera: étape 21, image 1 de 3 Samsung Galaxy Note9 Rear Camera Replacement, Remove the front camera: étape 21, image 2 de 3 Samsung Galaxy Note9 Rear Camera Replacement, Remove the front camera: étape 21, image 3 de 3
    • Use the tip of a spudger to pry the front camera connector straight up and out of its socket.
    • Use tweezers to remove the front camera.
  22. Samsung Galaxy Note9 Rear Camera Replacement, Remove the iris scanner: étape 22, image 1 de 3 Samsung Galaxy Note9 Rear Camera Replacement, Remove the iris scanner: étape 22, image 2 de 3 Samsung Galaxy Note9 Rear Camera Replacement, Remove the iris scanner: étape 22, image 3 de 3
    • Use the tip of a spudger to disconnect the iris scanner from the motherboard.
    • Use tweezers to remove the iris scanner.
  23. Samsung Galaxy Note9 Rear Camera Replacement, Disconnect the front sensor array: étape 23, image 1 de 2 Samsung Galaxy Note9 Rear Camera Replacement, Disconnect the front sensor array: étape 23, image 2 de 2
    • Use the flat end of a spudger to pry the front sensor connector out of its socket.
  24. Samsung Galaxy Note9 Rear Camera Replacement, Disconnect the display assembly: étape 24, image 1 de 2 Samsung Galaxy Note9 Rear Camera Replacement, Disconnect the display assembly: étape 24, image 2 de 2
    • Use the flat end of a spudger to disconnect the display cable from the motherboard.
  25. Samsung Galaxy Note9 Rear Camera Replacement: étape 25, image 1 de 2 Samsung Galaxy Note9 Rear Camera Replacement: étape 25, image 2 de 2
    • Use the flat end of a spudger to disconnect the touchscreen cable from the motherboard.
  26. Samsung Galaxy Note9 Rear Camera Replacement, Disconnect the charging assembly: étape 26, image 1 de 2 Samsung Galaxy Note9 Rear Camera Replacement, Disconnect the charging assembly: étape 26, image 2 de 2
    • Use the flat end of a spudger to disconnect the charging assembly from the motherboard.
  27. Samsung Galaxy Note9 Rear Camera Replacement: étape 27, image 1 de 2 Samsung Galaxy Note9 Rear Camera Replacement: étape 27, image 2 de 2
    • Remove the three 4 mm Phillips screws securing the motherboard.
    • There are triangles next to the holes indicating the motherboard screw locations.
  28. Samsung Galaxy Note9 Rear Camera Replacement: étape 28, image 1 de 3 Samsung Galaxy Note9 Rear Camera Replacement: étape 28, image 2 de 3 Samsung Galaxy Note9 Rear Camera Replacement: étape 28, image 3 de 3
    • Use a spudger to gently lift the motherbord from the upper-left corner.
    • Carefully remove the motherboard.
    • Move the ribbon cables out of the way as necessary. Do not pull the motherboard out if it becomes snagged on any cables.
  29. Samsung Galaxy Note9 Rear Camera Replacement, Remove the rear camera: étape 29, image 1 de 2 Samsung Galaxy Note9 Rear Camera Replacement, Remove the rear camera: étape 29, image 2 de 2
    • Use the tip of a spudger to pry the rear camera connector straight up and out from the motherboard.
  30. Samsung Galaxy Note9 Rear Camera Replacement: étape 30, image 1 de 1
    • Use a heat gun or hair dryer or apply a heated iOpener for about a minute to soften the adhesive around the rear camera.
  31. Samsung Galaxy Note9 Rear Camera Replacement: étape 31, image 1 de 2 Samsung Galaxy Note9 Rear Camera Replacement: étape 31, image 2 de 2
    • Carefully pick up the motherboard.
    • Using your thumbnails, press on the metal bezels to separate the rear camera from the motherboard.
    • Do not press on the lenses themselves if you don't want to damage the rear camera.
    • Stop once you feel the rear camera begin to separate from the motherboard. You don't need to press it entirely out yet.
  32. Samsung Galaxy Note9 Rear Camera Replacement: étape 32, image 1 de 2 Samsung Galaxy Note9 Rear Camera Replacement: étape 32, image 2 de 2
    • Insert the flat end of a spudger into the gap between the rear camera and the motherboard.
    • Lift to separate the rear camera from the motherboard.
  33. Samsung Galaxy Note9 Rear Camera Replacement: étape 33, image 1 de 1
    • Remove the rear camera from the motherboard.
3 autres ont terminé cette réparation.
Sam Omiotek
Membre depuis le 02/25/19
73 089 Réputation
288 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 15
30 derniers jours : 67
Total : 3,464
