Aller au contenu principal
Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement
Ce dont vous avez besoin
  1. Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Unplug your refrigerator: étape 1, image 1 de 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Open the freezer drawer: étape 2, image 1 de 2 Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Open the freezer drawer: étape 2, image 2 de 2
    • Slide the freezer drawer fully open.
  3. Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Remove the freezer bins: étape 3, image 1 de 3 Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Remove the freezer bins: étape 3, image 2 de 3 Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Remove the freezer bins: étape 3, image 3 de 3
    • Lift and remove all the freezer bins from the drawer.
    • You may need to open the refrigerator doors in order to remove the large bin.
  4. Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Remove the freezer door: étape 4, image 1 de 3 Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Remove the freezer door: étape 4, image 2 de 3 Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Remove the freezer door: étape 4, image 3 de 3
    • A plastic tab locks each drawer rail in place.
    • Use a flathead screwdriver or your fingers to press in the plastic tab near the inner end of the drawer rail.
    • While pressing the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
  5. Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement: étape 5, image 1 de 1
    • Repeat the rail unlock procedure on the other drawer rail.
  6. Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement: étape 6, image 1 de 1
    • Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
    • Remove the freezer drawer.
    • To reinstall the freezer drawer:
    • Push the geared torsion bar until it rests at the very end of the rails.
    • Align the drawer rails to the refrigerator wall guides.
    • Close the freezer drawer until the rails lock back in place.
    • If you don't hear a click, visually check if the plastic tabs have locked in place. You may need to push the rails in a little further with your fingers to set the tabs.
  7. Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Unfasten the icemaker assembly: étape 7, image 1 de 2 Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Unfasten the icemaker assembly: étape 7, image 2 de 2
    • Use a Phillips screwdriver to remove the two 18.5 mm-long screws securing the icemaker assembly to the freezer ceiling.
  8. Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: étape 8, image 1 de 2 Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: étape 8, image 2 de 2
    • Grasp the front edge of the icemaker assembly and tilt it downwards.
    • Don't try to remove the icemaker yet, as it's still connected by a few wires.
  9. Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement: étape 9, image 1 de 2 Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement: étape 9, image 2 de 2
    • Use your fingers to guide the wire harness out of the icemaker assembly.
  10. Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement: étape 10, image 1 de 3 Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement: étape 10, image 2 de 3 Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement: étape 10, image 3 de 3
    • Squeeze the icemaker cable connector and pull to disconnect it.
  11. Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement: étape 11, image 1 de 1
    • Remove the icemaker assembly.
Repair didn’t go as planned? Ask our Answers community for help.
Arthur Shi
Membre depuis le 01/03/18
255 248 Réputation
529 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
137 membres
17 523 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 30
30 derniers jours : 90
Total : 758
