Aller au contenu principal
Toshiba Satellite L55-A Battery Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L55-A Battery Replacement, Remove the RAM cover: étape 1, image 1 de 1
    • Before you begin, be sure to power down your laptop.
    • Flip the laptop over so that the back cover is facing up.
    • Unscrew the captive Phillips screw securing the RAM cover.
  2. Toshiba Satellite L55-A Battery Replacement: étape 2, image 1 de 2 Toshiba Satellite L55-A Battery Replacement: étape 2, image 2 de 2
    • Lift up the edge of the RAM cover and remove it.
  3. Toshiba Satellite L55-A Battery Replacement, Disconnect the ethernet connector cable: étape 3, image 1 de 3 Toshiba Satellite L55-A Battery Replacement, Disconnect the ethernet connector cable: étape 3, image 2 de 3 Toshiba Satellite L55-A Battery Replacement, Disconnect the ethernet connector cable: étape 3, image 3 de 3
    • Use an opening tool to pry up the ethernet connector cable from its socket near the RAM module.
    • Disconnect the cable.
    • During reassembly, make sure you re-insert this connector right-side-up. The connector is keyed to plug in only one orientation, so if it doesn't slide into place easily, turn it around and try the other way.
  4. Toshiba Satellite L55-A Battery Replacement, Remove the back cover: étape 4, image 1 de 1
    • Remove the thirteen 6.8 mm long Phillips screws securing the back cover.
  5. Toshiba Satellite L55-A Battery Replacement: étape 5, image 1 de 3 Toshiba Satellite L55-A Battery Replacement: étape 5, image 2 de 3 Toshiba Satellite L55-A Battery Replacement: étape 5, image 3 de 3
    • Insert the point of an opening pick in the seam between the SuperMultiDrive and the rest of the back cover.
    • Push the SuperMultiDrive's lip away from the back cover to disconnect the drive.
    • Slide the drive out of the bay and remove it from the laptop.
  6. Toshiba Satellite L55-A Battery Replacement: étape 6, image 1 de 2 Toshiba Satellite L55-A Battery Replacement: étape 6, image 2 de 2
    • The back cover is still held in place by plastic clips.
    • Insert the point of an opening pick into the back cover seam near the ethernet port.
    • Twist the pick to release the plastic clips along the edge.
  7. Toshiba Satellite L55-A Battery Replacement: étape 7, image 1 de 3 Toshiba Satellite L55-A Battery Replacement: étape 7, image 2 de 3 Toshiba Satellite L55-A Battery Replacement: étape 7, image 3 de 3
    • Grasp the loosened back case edge with your hand and lift it slowly away from the laptop. The remaining clips should release with ease.
    • If you meet significant resistance, stop and check for forgotten screws.
    • Remove the back cover.
    • To reinstall the back cover, align the cover and press along the edges to snap the clips back in place.
  8. Toshiba Satellite L55-A Battery Replacement, Unscrew the battery: étape 8, image 1 de 1
    • Remove the two 6.8 mm long Phillips screws securing the battery.
  9. Toshiba Satellite L55-A Battery Replacement: étape 9, image 1 de 2 Toshiba Satellite L55-A Battery Replacement: étape 9, image 2 de 2
    • Lift the battery out of its recess and move it slightly away from the motherboard in order to reveal the battery cable.
  10. Toshiba Satellite L55-A Battery Replacement, Disconnect the battery: étape 10, image 1 de 2 Toshiba Satellite L55-A Battery Replacement, Disconnect the battery: étape 10, image 2 de 2
    • Grasp the battery cable near its motherboard socket and pull the connector horizontally out of the socket.
  11. Toshiba Satellite L55-A Battery Replacement, Remove the battery: étape 11, image 1 de 1
    • Remove the battery.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Arthur Shi
Membre depuis le 01/03/18
253 250 Réputation
526 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
17 146 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 29
Total : 1,608
