Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations et tutoriels de réparation pour la version CDMA de l'iPhone de quatrième génération. Modèle : A1349 / capacité de stockage de 8, 16 ou 32 Go
Replacing the LCD the new digitizer cable seems to be too short.
I'm in the process of replacing the LCD with one that I bought on ifixit. During the reassembly (on step 15 of the guide) the Digitizer Cable won't reach it's place on the logic board. I've taken it back apart and started over and it still won't reach. The Digitizer Cable comes already attached to the new LCD assembly. Is it possible that it came too short? Is there something that can be done.
Please help, the longer it stays torn apart the more difficult it will be to put back together. I'm attaching two photos.
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
1 commentaire
I have the same problem too, I`ve took my 4s phone to bits 3 times, no cables nipped or anything but still too short about 1mm. anyway looking at it carefully it seems like its nipped in-between the front glass and the digitizer and pulling it might damage it. so when all comes to all its the people who make em its there fault...SEND IT BACK. Google images on ribbon lengths there is a difference.
par
Ajouter un commentaire
8 Réponses
Solution retenue
Once the cables are correctly pulled through the housing, the cables should be the same length.
Indice 2
1 commentaire:
I took it back apart (again) and found the Digitizer Cable was folded in half and stuck to the other cable. Problem solved and I just got the phone back together. It works!
Thanks
par
When reinstalling the display assembly, be sure the digitizer and display data cables are completely pulled through the slot cut into the outer case before pressing the display assembly down into the outer case. Failure to do so will cause the digitizer cable to not reach its socket on the logic board.
Was said in the step-by-step
Indice 0
Hopefully this helps someone out. It's a very common mistake.
http://www.iphoneshopusa.com/blog/iphone...
Indice 0
Super common mistake, GUYS DO NOT PULL ON THE CABLE!!! IT WILL BREAK AND YOU WILL BE LEFT WITH A USELESS SCREEN! Follow what everyone above is saying, be patient and make sure it's not being pinched in the back.
Indice 0
I can confirm the cable will tear ... right off if you are not careful!
First time I put the display back in it looked too short, so i retraced my steps and realised it had been folded over. I went through the process again and very carefuly made sure the cable was not pinched but as i moved it to plug it in the cable broke clean in two! :( It must have got pinched pretty hard on my first attempt. These cable ribbons are pretty delicate, certainly more delicate than me!
You live and learn i suppose!
Indice 0
4 commentaires:
I have taken mine apart 4 times now but it will not reach, it's not folded, snagged or anything.......are there different types????
par
Same ..my cable won't reach and is not trapped, folded etc :-(
par
Ya that just happened to me on my sisters phone. not folded or pinched. it just happened.
par
how do you know what types of sizes they are when you buy a new screen?
par
'Just &&^&@@ a brand new screen trying to pull the digitizer cable through. Here's what i should have done again but had to take it apart twice. Get a cocktail stick and gently prize the top open the digitizer cable already has a fold hence it sticks press down the fold and push the screen home so both ribbons go through at the same time. You will get what i mean simples DONT PULL OR A NEW SCREEN WILL BE NEEDED IT TEARS SO EASY. Sorry for the language frustration lol
Indice 0
Just f***** a brand new screen trying to pull the digitizer cable through. Here's what i should have done again but had to take it apart twice. Get a cocktail stick and gently prize the top open the digitizer cable already has a fold hence it sticks press down the fold and push the screen home so both ribbons go through at the same time. You will get what i mean simples DONT PULL OR A NEW SCREEN WILL BE NEEDED IT TEARS SO EASY. Sorry for the language frustration lol
Indice 0
if the cable is teared is it still salvageable? can it be fixed?
i honestly dont want to buy a new screen :/
Indice 0
Ajouter une réponse
chris sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 18
Total : 18,240
