LCD works but no backlight?
I have a MacBook with slight water damage that works perfectly through a CRT, I had it apart, had another MacBook and changed the screens out. What I found was that both the LCDs are perfectly fine, but I am not getting any backlight. I thought it may be the cable, but both cables won't backlight the screen. Should I buy another and try again, or do you think the logic board could be toast?
I looked for signs of damage, but like i said, it fires up just fine, works just like it should, except for the backlight. there seems to be a bit of carbon spotting(?) on the cable, and right at the connection.
Just wanted some opinions on what I should do next.
If nothing else, where is a good place to sell these other than ebay?
6 commentaires
it is an LED display, it all rides along the video cable.
par Ben
its an LED backlit display.
par Ben
Bad Inverter?
par Chris Green
thought i read that these don't have an inverter... where would it be located?
par Ben
It might be an LED display, and not have a backlight inverter, I didn't think of that.
par Chris Green
Afficher 1 commentaire en plus
