Aller au contenu principal
Version revisitée de l'iPhone 3G avec une vitesse de traitement plus élevée. La réparation de ce modèle est similaire à celle du 3G et nécessite de simples tournevis et outils pour faire levier. Modèle A1303 / capacité de 16 ou 32 Go / coque en plastique noir ou blanc.
1502 questions Voir tout
How can I repair my iPhone 3GS' speaker and motion sensor?
HELP! I replaced the glass with an iFixit part and guide, for my iPhone 3GS speaker and now the motion sensor and iPhone ear speaker (not speakerphone) is broken. I tried to reseat the cables multiple times and nothing worked! Any suggestions? Parts?
Répondre à cette question J'ai le même problème
Indice 5
2 commentaires
Brady, thanks for the input! I appreciate you getting back. I reseated the audio cable 5 times, while it was open i tested it, i think the heat gun may have damaged the sensor and the audio? What part can i buy, i need to get this fixed! The cable does not looked damaged. Any ideas?
par
Heat Gun?? you only need to use the heat gun for like 5 seconds on low. it doesnt take much to get the adhesive hot.
par
Ajouter un commentaire
3 Réponses
Réponse la plus utile
It sounds like (no pun intended) cable #3 is not fully seated within the connector on the logic board or the connector/cable is damaged. Although you have tried re-seating this connector, it never hurts to try again. Also, does the cable itself or the connector on the logic board appear physically damaged in any way? Make sure the connector's locking bar is flipped up before sliding the cable into the connector. Good luck!
Indice 4
2 commentaires:
In reply to: Re: How can I repair my iPhone 3GS' speaker and motion
sensor?
Brady Cabe wrote:
Although iFixit does not sell that part individually, the
contains iPhone 3GS display assembly that cabling. Good
luck!
Brady, not sure what you mean here, by "the contains" please advise! thank you.
par
It looks like a few words were missing there. Ha, sorry. What I meant to say is that the iPhone 3GS display assembly contains the cable you need to replace. Granted the part includes much more than you need, but because that cable is not sold separately, that is the best thing I can suggest at this point. Sorry I don't have a better answer for you :(
par
@ollie: it's normal that there's some space in between the white line and the connector. I've repaired several iPhones and I've never managed to get the cable in any further. BTW, dunno where you read that crap, but the lock is never gonna close by itself, no matter how hard you push the cable...
@the others: sorry for posting this as an answer, but I can't comment (yet?) and I couldn't find any PM system or the like
Indice 0
im having the same problem, i just chanced the camera
my prox sensor, speaker and my lcd backlight is gone
Indice 0
1 commentaire:
If the above answer did not solve your issue, please star a new question and state your symptoms. This question is 2 1/2 years old.
par
Ajouter une réponse
Mike Larson sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 18
Total : 43,345
