Sorry for the delay!
In terms of the model numbers, Apple sometimes gives very different machines the same model number, for some unknown reason. Unfortunately, having the same model number doesn't automatically indicate compatibility.
For the magsafe boards, they are the same form factor, but have different part numbers printed on them. I haven't personally tried to see if they are compatible in reality, but it could be a situation similar to the original MacBooks (the magsafe ports have different part numbers, but are interchangeable).
For the logic boards, the MBP 13" board is shorter and has different ports, which would also necessitate a new upper case. That gets very expensive!
In summary, the magsafe will fit, but it's your call whether you want to try it or not. The logic board is not interchangeable.
Good luck!
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
2 commentaires
I have all this info charted out, but don't have it with me. I'll be sure to answer tomorrow. Sorry!
par Ben Eisenman
Thank you ben, where can I get chart from?
par shockaaa
