Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Samsung Galaxy S3 est un smartphone multi-touch, au format ardoise, capable de suivi oculaire, au stockage accru et avec une option de recharge sans fil.
water damage no sound
Hi, i dropped my S3 i9300 in water, i opened it and let it dry for a day post that i cleaned all the connections and put it back together,, made certain all is connected nicely.
So the phone is working fine the touch is good, camera is good, i can send and receive sms, chat i can brows net,, etc
The problem is..
there is no audio on the mobile, i cannot listen to any music, no ringer, no sound, only vibration ..
i cannot make or receive call, the call goes through technically, no no audio,, so cant listen on talk..
Please help
Répondu ! Afficher la réponse J'ai le même problème
Indice 5
6 commentaires
did you ever get an answer to this? i have the same problem
par
Me too! Someone HELP!!!
par
Same here man only with my samsjng s4
T
par
My Samsung 1612 dropped in water and it's sound system does not work.
par
My LG k 500 n dropped in water yesterday.
I'd put it in charge.
My sound system is not working.
par
Afficher 1 commentaire en plus
Ajouter un commentaire
2 Réponses
Solution retenue
Hi gill,
Here are some suggestions:
1. Does the phone work on headphones/earphones?
2. Is the flight mode switched on?
3. Have you tried the app SoundAbout?
However, since your phone experienced a water damage, there could still be water on the motherboard that causes this issue. I recommend taking the phone apart (using this guide). Now lay the motherboard into isopropyl alcohol (90%) for about 10 minutes, take it out of this "bath" and let it dry for a couple of days next to a warm source (air conditioning, for example). Put everything together again and then test it again.
Steffen
Indice 3
1 commentaire:
It's not a phone it's a tablet
par
Same thing happened to me. I poured a little isopropyl alcohol into the bottom two holes and now everything works fine. DON'T BE AFRAID. Alcohol does not conduct electricity!
Indice 0
2 commentaires:
Hi there, this is a little late but can you give the exact steps of what you did?
par
Yes...please elaborate....did you have to some how get the ipa out afterwards?
par
Ajouter une réponse
gill sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 28
Total : 51,200
