Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Mis sur le marché en juin 2009 / Avec processeur Core 2 Duo cadencé à 2,66, 2,8 ou 3,06 GHz
Airport Card - Antenna connector broken
Hi Guys,
I just broke my Airport Card Antenna connector from the Airport Card. There are 2 connectors - "J1" and "J2"
J2 is fully broken from the airport card, but the WiFi is still working. Do you have any idea what is the "J2" connection for...? is it just for boost the signal ?
Thanks!
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
3 commentaires
Have you tried your bluetooth connection to see if it's still working? I believe the Airport antennae also handle bluetooth, but I'm not sure.
par
Yes, both working.
Here is a photo from the broken part:
http://www.herbalfire.com/1.jpg
par
Hmm, I can't feel any changes in the strength of signal.
par
Ajouter un commentaire
2 Réponses
Solution retenue
I think there are two antennas located in the MBP display. You're getting a signal probably because one antenna is still connected to the airport card.
Indice 1
I think one of the connector is exclusive for 5Ghz operations, or both connectors are dual band, losing one just means losing a MIMO chain. It only impacts top performance, which is rarely approached.
Indice 0
1 commentaire:
Thanks a lot.
par
Ajouter une réponse
csaba sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 16
Total : 1,995
