First thing I would do here is make sure the vents on both the top and bottom of the system are free and clear of and papers or other objects.
Next I would get a vacuum out and clean the vents (top & bottom) of any dust build up. You may need to use a brush to dislodge anything.
If you find there was nothing blocking the venting externally then you'll need to go deeper.
Download from the App store or other source a temperature monitoring app. Monitor the temps from the display & CPU/GPU's. What is getting hot? Before and when you raise the brightness just before the display goes black.
Are you up to opening your system? Do you have the correct tools and an ESD mat and wrist strap? If you are up to it continue. If not it's time to get your system in to an Apple Store or an authorized Apple service center for deep cleaning and possible repair.
Review the iFixIt guide and open the system up using a soft brush and compressed air (canned air) blow out the dust and clean the heat sink grills of the CPU & GPU. Do not use a vacuum here!
If the system was not dusty and the display was overheating, you'll need to open it up to check the sensor and may need to replace it or the display.
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
3 commentaires
Try lowering the brightness to a very low setting does it appear to take longer for the display to go black? Also have you tried an external monitor to see if there is any difference?
par Dan
I tried what you suggested about lowering the brightness and it seems to be working.
I haven't responded sooner because I wanted to test it before I said anything.
I lower the brightness about 25%. Then I tried raising the brightness a little and it didn't work. The screen started to go black.
So the 25% setting seems to be working. That was a great idea.
Why do you think it's working by lowering the brightness?
I hope it continues to work....I'll let you know if it doesn't.
Thanks for the suggestion.
par Peter
This was a diagnostic trick to isolate out the cause of the screen going out. Your problem is within the display it's self. The thermo sensor on the display panel is either going bad or the display it's self is over heating.
par Dan
