I'm with Gord...I think it's that ATI had a bad batch of X1600's and it's corrupt or bad onboard video card memory. It could also be bad solder joints, thermal paste, etc.. but the damage from the first time it happened has likely caused irreversible damage to the involved components.
I'm running SMC fan Control and it helps, but you can forget about playing video games. Not for very long at least. If the vid card gets too taxed, the screen will either go black (tho the OS is still running), or the machine will just freeze up. It's all due to the faulty vid card, I'm convinced. I just use it for every day applications, and do nothing that I want to do on the machine. I'm hoping for a new iMac soon, and doubtfully will be able to get any money for this machine on eBay. Parts? The parts everyone wants is the part that is bad on my machine! Plus, my screen has some light scratches on it from my toddler son messing with it.
When I get a new one, I'll probably put a bullseye on the machine and squeeze off a few rounds in the back yard. That would be worth the $50 I'd get on ebay for it.
And for the record... it's the ONLY Mac of MANY that I've ever had a problem with.
Jason
Cette réponse a-t-elle été utile ?
A voté
Annuler
Indice
0
Did you connect the iMac to an external monitor ?
par lemerise
I will try that and report back.
par Eric Drust
I tried a 17" LCD with the DVI connection and it had similar issues. On my built in 20" monitor I get weird horizontal lines, but this did not happen on the 17". However, I get image tearing on both of them, and maybe it would just be a matter of time before I see a line issue on the 17". I ran it in extended desktop mode for about an hour.
par Eric Drust
